Previous in Forum: CAN I BRACE A HVACR LINE WITH R410a / R407c INSIDE   Next in Forum: Force by Rubber Compression
13 comments
Handwheel Shaft Locking/Unlocking!
02/28/2013 2:23 AM
I tried to search for this device online with no luck. Most likely because I'm not using the correct terminology. I saw it once a long time ago mounted on a gearbox shaft just in front of the hand wheel. It was a spring loaded collar type of gizmo that you pull towards the handwheel, turn 90 deg, and release. In this position it allows the input shaft to turn. Pull it again, turn back 90 deg, release, and it engages onto the bolt head of the gearbox's inputh shaft cover. This locks the shaft and prevents it from turning. It was a nice compact little unit and I'm trying to find some for various manually operated worm gear drives. This thing looked like a standard purchased item but it could have been a custom job. Have any of you seen anything like this before? If so, do you know where I might find them. Worst case I could probably fab something similar but I'd rather not spend the time if possible. Thanks.
Re: Handwheel shaft locking/unlocking!
02/28/2013 6:59 AM
I didn't download the catalogue, but maybe.
http://www.lovejoy-inc.com/products/shaft-locking-devices.aspx
02/28/2013 9:47 PM
I'm familiar with Lovejoy couplings and they don't anything like I described. Thanks anyway. Judging by the overwhelming number of responses...it seems like I saw on a gearbox years ago must have been a custom device.
Re: Handwheel Shaft Locking/Unlocking!
02/28/2013 10:58 PM
what you are describing is a brake or clutch unit. these can be had in all versions. electric pneumatic hydraulic and manual. search for gearbox brakes.
good luck
03/01/2013 6:06 AM
I see these things every day. They are a dog clutch used to engage and disengage the drive to the wheels on some brands of wheelchairs. You could source it as a spare part. Unfortunately the chair I know for sure it is on is an Australian made chair, where are you?
Jim
Good Answers: 153
03/01/2013 6:21 AM
Check out a Gates Draughtguard™anti-rotation device @www.gates.com
Canada - Member - New Member
Good Answers: 11
03/01/2013 9:31 AM
Was intrigued and checked.
Would be Gates Draftguard: http://www.gates.com/news/index.cfm?id=11291&show=newsitem&location_id=752
03/01/2013 10:55 AM
Dog clutch!...that's what it looked like (that's the word that didn't occured to me). I found the picture below on practicalmachinist.com and it looked almost identical but served the oposite purpose. The picture below shows the clutch keyed to the shaft after the hand wheel. When it's pulled back (as shown) the hand wheel is what rotates freely. This arrangement does not lock the input shaft. The the clutch I saw was in between the hand wheel and the gearbox input shaft cover. The slots in the dog clutch engage onto the protuding socket head cap screw heads of the gearbox input shaft cover. Since the clutch is keyed to the input shaft, it prevented the shaft from rotating.
At least now I'm on the right track. Thanks for the tips. I'm still thinking the thing was custom because it was installed on a standard Boston Gear worm drive unit. Those don't have a long enough keyway or input shaft to allow the installation of a clutch like this. I wish I had a picture of it.
Good Answers: 119
03/01/2013 11:20 AM
In this instance, if I remember correctly, the only reason the dog doesn't engage a shaft when it disengages the handle is because there is a separate clutch to engage the carriage leadscrew. The dog on the handle was only to release the handle so it wouldn't whack the operator in the hip after engaging the leadscrew.
Of course I can't remember the amount of times I forgot to disengage the handle and got whacked anyway!!
Hooker
Good Answers: 123
03/01/2013 1:14 PM
At least you didn't get whacked by Uncle Vinny.
Bob
Good Answers: 119
03/01/2013 1:33 PM
True, but I could've defended myself against Uncle Vinny. The lathe had unfair advantage!!
Good Answers: 153
03/01/2013 4:39 PM
The previous item I suggested stops it reversing but does not lock it stationary. I don't know of a single proprietary item to achieve this but a shaft collar with one or more holes drilled into the edge, a latching 'indexing plunger '(Google for suppliers), and a bracket would be simple to construct.
03/03/2013 12:37 PM
Thanks for the suggestion. I've also used the handwheel itself with holes drilled radially.If the hub is long enough you can get away with it. The problem with these indexing plungers is that they are not very robust. I haven't found one yet that can stand up to reasonable abuse. I still use the arrangement for certain applications because it's simple but I was hoping to find a stock "dog clutch" type of component which is more robust.
Regards
03/04/2013 8:16 AM
The indexing holes can be positioned axially as well. A stronger, custom
made pin and a simple mechanism can privide a lot more shear section and
longer life. Contact info: www.tttool.com
Register to Reply 13 comments
bob c (1); enger (1); gigaconcept.com (1); Hooker (2); jhhassociates (2); JIMRAT (1); kramarat (1); scrapper (1); TerraMan (3)
