Previous in Forum: Design Vacuum Pressure   Next in Forum: Reaction Between Copper and Nitric acid
Grading Frac Sand
02/28/2013 6:13 PM
Is there any technology using a micro scan method to grade frac sand? Versus the current shake and screen weigh method.
Do Good Do Well
Pathfinder Tags: Frac Sand
Re: Grading Frac Sand
02/28/2013 6:20 PM
Did you ask the Frac Sand Man?
News for frac sand companies
02/28/2013 7:07 PM
Yes, the Frac Sand Man is asking, about nano technology, related to the question. A device to take a picture of flowing sand to determine it's grade according to NISA.
Mr. Sandman
02/28/2013 7:19 PM
You didn't ask about nano-technology until now.
Technical Aspects of Implementing Rapid Aggregate Gradation - aftre
Bye.
Good Answers: 153
03/02/2013 5:28 AM
A horizontal air current has for millennia been used to winnow chaff from a falling curtain of grain. Applying this technique to sand grading, smaller grains of sand would weigh less and would be deflected further by the air stream. A series of parallel slots placed on the far side of the sand curtain receiving trough would collect different weights of sand grains. (assumes that weight is correlated to size)
Or why not make use of a property that is present in inefficient cyclones used to separate particulates from air in a pneumatic conveying system. If a cyclone is set up incorrectly, a quantity of 'fines' get carried over with the exhaust air while the majority of the heavier particulates drop out at the base of the cyclone. The fraction of 'fines' in the exhaust air is increased as the air flow rate is increased beyond the cyclone capacity. If you can calibrate the air flow rate against to the particle size retained in the exhaust air, you should be able to make a crude separation of the bulk sand. This may be sufficient, or your current shake and screen would then be more productive.
I have never seen this feature of cyclones employed deliberately, just flying a kite on this one.
03/02/2013 8:18 AM
thanks, no body said it was going to be easy!
United States - US - Statue of Liberty - How's it going?
03/04/2013 10:29 AM
Photo-Optical Particle Size Analyzer, made by a couple different manufacturers. They claim to get nearly instant results. with out all the shaking and weighing. WS Tyler makes one that I have seen. I haven't seen it in use and I don't think they are cheap.
If you can't explain it simply, you don't understand it well enough. AE
03/04/2013 11:54 AM
Thank you very much
Register to Reply 7 comments
jhhassociates (1); Juker (3); lyn (2); nvirciglio (1)
