Previous in Forum: Is it advisable to connect a plate heat exchanger at the suction of water pump   Next in Forum: .eeg File
9 comments
Gate Valve
02/28/2013 11:27 PM
can anyone help me with gland flange (oval) thickness calcuation for gate valve when applied with upward thrust?
“A little knowledge is a dangerous thing. So is a lot."
Re: Gate Valve
03/01/2013 3:48 AM
What size valve?
Re: Gate Valve
03/01/2013 3:54 AM
DN150 PN16 soft seated valve suitable for austrailian standrad.
the gland flange should hold the upward thrust of 110,000N. with 2 bolts & flange is oval type. it consist of o-ring to seal the stem.
Re: Gate Valve
03/01/2013 4:41 AM
In what material does the flange need to be made?
What is the diameter of the studs that pass through it?
Re: Gate Valve
03/01/2013 4:46 AM
The material is DR Brass
The screw size is M12x25 on the both side
In the center the shaft diameter is 24mm
You can forward with some assumption for the missing data, I shall inculde the data from my side & do it again. I need only the steps
Re: Gate Valve
03/01/2013 5:18 AM
15mm would probably do it. How does this figure compare with other makes of valve?
Re: Gate Valve
03/01/2013 5:40 AM
I have used 11 mm lower side which has bigger diameter & 13 mm upper side bit smaller size overall we have used 27 mm, but when test for upward thrust of 110000N. It started bending in the middle.
Re: Gate Valve
03/01/2013 7:32 AM
Then it ain't thick enough. Make it 40mm and try again.
Re: Gate Valve
03/05/2013 2:12 AM
I made calcualtion with ASME Section with UG-34, it shows 39.+,
Now I am trying with this thanks for your answer.
Re: Gate Valve
03/01/2013 4:51 AM
The material is DR Brass,
The Screw size is M12 two numbers on the either side used for fixing to the bonnet.
In the cernter the shaft diameter is 24mm,
If you has some method how do it please forward
Register to Reply 9 comments
Anonymous Poster (2); PWSlack (4); Srinivas Hurali (3)
