Previous in Forum: Reaction Between Copper and Nitric acid   Next in Forum: Film Breaking in Packaging...Anyone Else?
Sheetmetal Mike
03/02/2013 8:59 AM
I had a drive way poured a couple years ago then built a cover over this to keep the truck out of the weather.The problem that I am having is they put a smooth finish on this concrete slab(should have made them rip it out and (re do the whole drive).
This is so slick when it gets any moisture on it that someday someone is going to fall down. Is there a product that I can apply to this concrete that will last,or some kind of etching to take the smoothness away?What can I do to this concrete?
Pathfinder Tags: concrete
Re: Sheetmetal Mike
03/02/2013 9:09 AM
There various options. One is an exterior grade anti-skid paint. You can buy it from Home Depot:
http://www.homedepot.com/buy/sure-step-1-gal-acrylic-gray-pearl-anti-slip-concrete-coating-su-0308.html
Re: Sheetmetal Mike
03/02/2013 9:13 AM
It's a good idea to seal the concrete.... Concrete sealer is available at the local Lowes or Home Depot....Just add the grit they sell for just this purpose...or you can just etch the concrete....I personally would etch it first then use a stain sealer with grit...
http://www.concretenetwork.com/products-sealer/
http://www.sealkrete.com/acid_etching_no_cne.htm
Re: Sheetmetal Mike
03/02/2013 10:07 AM
You will have to roughen the surface before applying any non-skid product anyway, so you could just rent a floor grinder, and skip putting on the coating.
http://www.youtube.com/watch?v=5_Nch4v7LOQ
Re: Sheetmetal Mike
03/03/2013 9:56 AM
you could have it scarified. in thisprocess small steel "shot" is shot at high pressur at the surface of the concrete.
CARPE CRUSTULORUM!
kramarat (1); lyn (1); not so smart (1); SolarEagle (1); Usbport (1)
