Previous in Forum: Star-Delta Stater for Which KW?   Next in Forum: Designing Buck Converter
Usage of 3P+N VS 4 Pole
03/02/2013 9:18 AM
where in electrical installations 3P+N is used...? and 4 Pole is used....????
Good Answers: 117
Re: Usage of 3P+N VS 4 Pole
03/02/2013 10:51 AM
you need to look at your question and re-write it.. it makes no sense!
Sorry my friend, but that's the reason you've had no answers
03/04/2013 3:22 AM
Elsewhere than in the UK is the simple answer. Switching a neutral is contrary to all the good sense contained in British Standard 7671.
Good Answers: 244
03/06/2013 6:42 PM
This comment may help you:
http://cr4.globalspec.com/comment/560522
- MS
Good Answers: 44
03/07/2013 3:17 PM
Yikes...
3P+N is used at the input of a distribution transformer...
If you saw a 4-pole breaker you may be confusing that with a 4 phase system, which would be quite esoteric to begin with.
4-pole breakers were at one time used for building up the service by using lower ampacity breakers in parallel for, say, a split-phase service to a residence (US). For example, a 100 Amp service could use four 50 Amp breakers with each phase utilizing two 50's in parallel.
Register to Reply 4 comments
brich (1); cuba_pete (1); msamad (1); PWSlack (1)
