Previous in Forum: Convert 220 3 Wire Circuit to 110 Volts   Next in Forum: SPAM 150C Relay Testing
Gate Driver Design for irf840
03/03/2013 7:26 AM
i ma using irf840 to make a dc-dc converter.For the gate driver part i am using npn and pnp BJT to meet the current requirement.the current requirement for the gate to turn on if around 4 A.during turn on the npn helps the gate to charge and meets the current requirement.similarly when 0 level is received from TTL, the gate discharges through the pnp.
However to decide the rating of the d in the charging and discharge path, do i need to take 3 A as reference or not(since the average power requirement of the devices are low, as the gate requirement of current is high but for a very short period of time~20-30nS).
Please help me out or suggest some other circuit.Is there any gate driver IC for driving irf840???Please suggest some useful reading material for design of gate driver.
In search of the truth
Re: gate driver design for irf840
03/03/2013 8:23 AM
IRF840 is a low power MOS. Instantaneous current of the gate is small depends on parasitical resistance and capacitors of driver . One can use a pair BC327/337.For drivers looking for www.irf.com schemes. And on net too. Have many applications at that address.
Falun Dafa is the path to human immortality. You just need to follow it and believe in it. Is the human user manual and it was stolen until now..
Good Answers: 82
Re: Gate Driver Design for irf840
03/04/2013 9:57 AM
Unless you need fast switching, below 50ns, it's customary to add a series gate resistor to slow down the switching and avoid inductive V = L di/dt spikes, which can damage the MOSFET's gate and cause other problems. If you add a say 47-ohm resistor, that will limit the current to about 100mA, and you can use a simple transistor circuit for gate driving. But in any case you will need 10V or more for the gate-drive voltage with an IRF840 or any other 500-volt type.
But if you do need fast switching, or to obtain a 10 to 12V gate drive from a logic input, then definitely use an official gate-driver IC. There are plenty of cheap ones available, such as the classic TC4426 (datasheet link) dual inverting 1.5A driver, or TC4427 (noninverting), $1.39 each at Mouser.
Thanks, Win
Register to Reply 2 comments
