Previous in Forum: Selection of Bearings with Sleeve Nut or without Sleeve Nut and Lock Washer   Next in Forum: Source for Small 12V DC Gear Motor
Drain System and Static Pressure
03/04/2013 9:36 AM
how to design drain system based on static pressure of AHU/blower
or how there are interlinked what are the causes/disadvantages for improper design of drain system without considering static pressure of AHU/blower
please explain this
Re: Drain System and Static Pressure
03/04/2013 11:02 AM
Somewhere in the drain there will (usually) be a trap to prevent unwanted air from moving in or out through the drain pipe. The net depth of the trap must be greater than the maximum expected static pressure of the AHU.
03/05/2013 8:00 PM
"causes/disadvantages for improper design"
Causes: no relevant knowledge, experience or education of the designer.
Father/uncle owns company allowing someone with, no relevant knowledge, experience or education to be the designer.
Disadvantages: The thing won't work right. Someone will lose money, hopefully a father or uncle.
You might consider some mechanical engineering courses, if you want to design stuff.
05/06/2014 3:52 AM
The following link may help you:
http://0323c7c.netsolhost.com/docs/Trane_-_Trapping_Design_Flaws%5B1%5D.pdf
or google for condensate drain or U trap drain AHU .
Register to Reply 3 comments
lyn (1); Musthafa (1); Tornado (1)
