Previous in Forum: Film Breaking in Packaging...Anyone Else?   Next in Forum: Conditioning a Graphite Crucible. Urgent!!
Active Filter
03/05/2013 1:59 PM
Hi this is my present problem ...I want to separate particles of 50 -100nm size in a aqueous solution can anyone point me in the direction to get these small grid sections of a reasonable size. I was thinking that I will need to agitate at HF to separate the particles from the carrier.. What Is your opinion on Piezo to do this Thanks in advance
Torque is not cheap
Pathfinder Tags: 60nm
Re: Active Filter
03/05/2013 3:43 PM
Depending on volume to be processed and the ongoing timeframe there are filter materials and systems readily available.
We have recently commissioned a water treatment facility and there were multiple options for exclsion level for the cartridges, with air scour backwash to clean the membranes and so on.
If you look up "Membrane filtration" (There are some options here on CR4) you will find many options with different flow throughputs and with the selectivity that you describe.
To protect the membranes though, you might want to install a more coarse filter in front.
Alternativey, if the particles are "organic" there may be options in activated carbon, depending whether you need a physical barrier (Membrane) or not.
Re: Active Filter
03/06/2013 3:11 AM
The difference in density is important. Centrifugation may be an option.
Any idea on quantities and flowrates that could be shared?
Re: Active Filter
03/07/2013 7:28 AM
The TOTAL amount of fluid would amount to no more than 200ml and the flow rate would be gravity assist with a small amount of pressure say 0.5 bar. This really needs a small filter not a large capacity unit, and the filters need to be removable to be able to examine the different deposits on the different graduations
Torque is not cheap
Re: Active Filter
03/07/2013 3:34 PM
Ok,
We use units for checking water quality with "paper" filters clamped between holders and then fitted into the top of a conical flask.
To assist the filtration rate, the flask is connected to a small vacuum pump.
If you search for "labware" or "Glass labware" you should get some contacts.
Re: Active Filter
03/11/2013 3:01 AM
When talking nano >20 is the clamp system satifactory regarding leakage ?
Torque is not cheap
Re: Active Filter
03/11/2013 4:35 PM
The filter material is around 75mm diameter with an exposed opening of around 20mm.
I'm not in the lab so cannot comment beyond the fact that they are using it in preparation of samples (removal of contaminants) before conducting assay testing for disolved materials.
If the "Cole Palmer" group is still operational, then they may be able to give you more targeted information. (That's the mob that I used in the past for the lab that I was managing.)
Register to Reply 6 comments
Just an Engineer (3); merc600sec (2); PWSlack (1)
