Previous in Forum: Motor Generator Frequency Converters Manufacturers   Next in Forum: Defining Size and Location of Capacitors in the Electrical System
Electrical Problem With Toyota Avensis.
03/06/2013 5:32 AM
I have a Toyota Avensis model AT22IL-ALPEKW, EFI-electrical fuel injection system, engine 7AFE [1800cc 16 valves-DOHC]. The car had mechanical problem last December 2012 . Since after fixing the car I having been experiencing occassional trips of the engine which was linked to electrical problem.
Could you please suggest the likely/exact cause of the occassional engine trips.
Regards,
waeoka
Re: Electrical problem with Toyota Avensis.
03/06/2013 5:49 AM
Not without some more detailed description of what happens; no-one could do it!
Re: Electrical Problem With Toyota Avensis.
03/06/2013 9:52 AM
What is the nature of the mechanical issue that was repaired?
Do you believe that this repair contributed to the current electrical problem? Why or why not?
Who has linked these occasional engine trips to electrical problem? What does he have to say about the probable cause and subsequent remedy?
As previously stated, you really haven't given us much to go on.
03/06/2013 10:13 AM
Good mechanics are hard to find....my advice is to network with other owners to find a good one....
http://www.toyotaownersclub.com/forums/index.php?showforum=51
Register to Reply 3 comments
Doorman (1); PWSlack (1); SolarEagle (1)
