Previous in Forum: Waste Water   Next in Forum: Milling Aluminum With a Slow Speed Drill Press
8 comments
Steel Castings
03/08/2013 4:12 AM
Hi. We pour steel castings. recently we have observed gas porosity defects around the risers. No other area. We changed the type of exothermic sleeves we use. But still no relief from the defect. The depth of the defect is not more than 20 mm. But is observed around the riser. especially risers near the thinner section. Any help ?
User-tagged by 1 user
Re: Steel Castings.
03/08/2013 5:00 AM
It could be any number of things....best thing to do is run down the check list and see what jumps out at you as a possibility....
http://en.wikipedia.org/wiki/Casting_defect
http://ebookuniverse.net/international+atlas+of+casting+defects
Re: Steel Castings.
03/09/2013 7:34 AM
Thank You.
Re: Steel Castings
03/09/2013 6:25 AM
/!\ beaware of my replies coz of non-specialit's
perhaps::
http://www.bing.com/search?q=steel+metallurgy+370+670&src=IE-SearchBox&Form=IE8SRC
ci139
Re: Steel Castings
03/09/2013 6:54 AM
Electrical potential differences between risers and the "ground"? May be very low level.... Before pouring, use a sensitive voltmeter.....make sure that you check using both AC & DC settings.....
Best of luck.
PS. A ground strap may be all that is needed. Maybe the problem ONLY happens when the pour is doe, some electrolytically produced reaction for example.....
Re: Steel Castings
03/09/2013 10:45 AM
Abhijit I believe from your posting that you are using exothermic sleeves as feeders and these are very susceptible to moisture pick up and seem to be your problem.Please ensure that your stocking of sleeves is free from moisture. Moreover I suggest to switch over to insulating sleeves which will behave better and the problem as described by you will be overcome.
Re: Steel Castings
03/11/2013 2:52 AM
Hello. But will the insulating sleeve feed the casting ?. What is the maximum insulating riser size that can be used to feed the casting ?
Re: Steel Castings
03/09/2013 12:27 PM
Are your molds really dry? Have they been sitting long after bake-out?
Accumulated moisture in the mold will be driven towards the exits(risers), and will condense around the opening producing hydrogen when hit by the molten metal. Hydrogen is soluble in molten steel.
Just a thought.
Good Answers: 21
Re: Steel Castings
03/09/2013 8:19 PM
I worked for a company that manufactured fifth wheels and other thin section castings. The problem you mentioned can just drive you nuts. There has been some good advise from the group here, but like always we can not see the issues, only guess from the description provided. I would suggest calling on your sleeve, mold wash supplier and to your pattern makers for help. They can put thier eyes on the issue and better solve this with out a lot of guessing.
Register to Reply 8 comments
Abhijeet76 (2); Andy Germany (1); Balraj Seth (1); ci139 (1); fixitorelse (1); Gene Hayes (1); SolarEagle (1)
