Previous in Forum: 33kv Fault Level Calculation   Next in Forum: Cut-Off Current
Need Technical Detail of Energized Cable Sensing Device
03/08/2013 7:38 AM
Dear All, In our MCC (Motor control center ) we are having 15 number of Ring main units with Schneider 11kv,RE2c type. And we are getting supply through 2 feeders from FEWA (sub station ). this is the thing if any fault comes in RMU (Ring Main unit) corresponding RMU will trip and main feeder will trip due to fault type,if this happens we have to check each RMU which is tripped because we don't have any monitoring system for RMU. At the same time we feeling difficult to fix fault locator (due to shutdown ). So we need a detector which will detect from outside of cable, we are using trefoil 630 sqmm xmpl cable (so we can't use CT). Any sensor's available,just we need to know which RMU's power gone first (with in some millisecond ).
Our idea is by using Electromagnetic field, it is suitable or any other method is there ? What about MEMS (Micro Electro Mechanical System) can i use mems as a live cable sensor.
Re: Need Technical Detail of Energized Cable Sensing Device
03/08/2013 11:25 AM
What does the manufacturer of the equipment say?
Get a monitoring system for the RMU's? That's what I'd tell you if you had bought the equipment from my company.
Or, hire an electrical engineer who knows what to do.
You're spending money uselessly checking everything. Get smart, hire an engineer.
Reply to Forum Thread
