Previous in Forum: Questions Regarding "Plugging" of Induction Motor   Next in Forum: Need Technical Detail of Energized Cable Sensing Device
33kv Fault Level Calculation
03/08/2013 5:11 AM
Total capacity of Transformer 2500KVA 33KV/433V X4Nos =10000KVA, So i want HT Side fault level calculation and total Amps.
Re: 33kv fault level calculation
03/08/2013 5:55 AM
Hire an Electrical Engineer.
03/08/2013 6:55 AM
Good Answers: 131
Re: 33kv Fault Level Calculation
03/08/2013 10:05 AM
Fault level on the high side of the transformers will depend first of all on what the utility can provide, so you have to start there. They will have fault current levels for your connection. If you are downstream from that point in your own (privately-owned) system, you will need to do a system fault analysis to find out what the currents are at the transformers. This will also have to include any contribution from generation that you have on site.
As someone else said, hire a qualified electrical engineer to do the analysis for you.
Good Answers: 19
03/09/2013 12:42 AM
The ht side fault current depends on source fault level indicated by EB grid. This will not have any bearing on your transformer capacity and no of transformers, as long as you do not generate power and export to utility grid.you should find out the fault currents down stream and select devices suitable to withstand such fault currents.also protective relays are to be set based on such fault currents.
Ramesh,Freelance Electrical/automation Consultant
04/11/2013 7:05 AM
HT side is 1750amps at 10MVA
Anonymous Poster (1); nobodysomebody47 (1); PeterT (1); PWSlack (1); ramvinod (1)
