Previous in Forum: Oil Type Vs Vacuum Type Tap Changer   Next in Forum: PAT
How to Control Home Incoming Electrical Power?
03/11/2013 1:56 AM
Some times there are electrical problems occurs in incoming power at home. It burns TV, refrigerator , fan, lights and some home appliances also. I have put ELCB / MCB of 15 Amp at main board to prevent internal short circuit but it can not control incoming power. What can be done?
Re: How to control home incoming electrical power?
03/11/2013 2:24 AM
Sounds like you need some form of power conditioning.....
that is a pretty broad term though. Could you describe the types of electrical problems and anything you might have noticed about how the appliances fail?
03/11/2013 3:27 AM
I describe like this.
Incoming Power is 240 VAC single phase.
Every thing in house working good.
All of a sudden from main line some disturbance is occurs in main transformers where the electric power distributed in area.
It fuses so many houses light, fans , TV and other.
But somewhere in the same distribution not a single appliances even light bulb.
I suspect phase changing or something else as i am not an electrician.
I want my hose to prevent from it.
How to do?
03/11/2013 5:00 AM
Neutral is getting disconnected on the pole.
Gajanan Phadte
Good Answers: 58
Re: How to Control Home Incoming Electrical Power?
03/11/2013 8:45 AM
Have you looked into residential surge suppression devices?
This is one way to protect your equipment/appliances.
This could get costly though.
Depending upon the severity of the surge/spike event, this usually (but not always) takes out the MOV's (metal oxide varistors).
Here is a pretty good read for you.
There are different types of surge suppressors available also. Here is another good read.
As gmphadtw pointed out, you may also have a floating neutral. IMO the most cost effective route would be to check (or have someone with experience do it for you) the integrity of the neutral connection(s).
03/12/2013 11:52 AM
To get a more clear picture connect(hire) a power analyser after the utility meter and record all parameters(V,I,instantaneous,Hz,Pf,THD,kw,Var,kVA etc) of your supply.
pnaban
bankimbhatt (1); gmphadte (1); KJK/USA (1); pnaban (1); truth is not a compromise (1)
