Previous in Forum: Uncleaned Power Supply   Next in Forum: High Voltage Electrical Clearance
Transformer Capacity
03/11/2013 6:27 AM
How to calculate the transformer capacity (in kVA) rating for a 3 and single phase transformer if name plate missing from tranformer. and how do we know the actual input and output voltage of this transformer. ???
"Keep work and family separate. "
Pathfinder Tags: kVA ratinfg of transformer
Re: Transformer Capacity
03/11/2013 6:36 AM
Historical records:
  • Look at the commissioning documentation. It will be in there.
  • Look at the maintenance records. It will be in there.
  • Look at insurance records. It will be in there.
  • Look at the purchase records. It will be in there.
  • If its delivery date is known, go back to the supplier and eliminate the ones that do have nameplates fitted from the delivery record.
It really shouldn't be in operation if the nameplate is missing and its rating is unknown, as how would anyone know what the settings should be on its overload protection equipment (rhetorical question - NNTR)?
03/11/2013 2:44 PM
Practical answers. The homework answer is you perform certain measurments on the primary and secondary windings along with.....(see post #3)
03/11/2013 7:26 AM
a good way to have a hint, would be just the size of the transformer. a big one will have more power reserve. just a hint... you can also have a look on the protection gear of the machine, and then have a more inside reading... if not the intire one!
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
03/11/2013 2:42 PM
Additionally this question has been answered a number of times on CR4, so also try a CR4 forum search.
Register to Reply 4 comments
electronick (1); jack of all trades (2); PWSlack (1)
