Previous in Forum: Protection of Earthing Grid from Corrosion   Next in Forum: MCC
Merlin Gerin (MG) Main Circuit Breaker Faulty
03/12/2013 5:09 AM
Dear All,
We have a diesel genset of Caterpillar -725 kVA model 2412. The main circiut breaker got faulty.
MG - C1251N 1250 Amp
Please advise the possible causes of faulty breaker.
Thanks
Re: Merlin Gerin (MG) main circiut breaker faulty
03/12/2013 5:24 AM
  1. The first possibility is overload.
  2. The next is water ingress.
  3. A third would be mechanical damage.
  4. Overheating from outside.
  5. Etc., etc.
03/12/2013 5:55 AM
6. Ingress of foreign objects...
Good Answers: 131
Re: Merlin Gerin (MG) Main Circuit Breaker Faulty
03/12/2013 7:27 AM
7. Lack of maintenance: cleaning, lubrication, etc...
Good Answers: 69
03/12/2013 8:58 AM
8.- Loose conections causing overheating and metal erosion.
03/12/2013 10:21 AM
What's the prize for getting it right? Only, Del the cat wants to know...
France - Member - New Member
03/12/2013 10:44 AM
Main infos needed :
  • ref of the breaker
  • type of network, installation
  • type of failure : "faulty" is a bit vague.
Then I would advise to call the Schneider service center ...if Caterpillar does not answer.
Good Answers: 122
03/13/2013 12:00 PM
You did not state what type of breaker is in question.
If it is a molded-case type breaker:
Most molded-case circuit breakers are not designed to operate/trip/open more than once under fault conditions.
If this breaker has operated more than once in/under fault condition(s) it must be removed from the application and tested using a certified tester and following the breaker tester IOM instructions.
Not knowing if or how many times the breaker has been "tripped" in/under a fault condition nor the operating environment nor whether it has been properly maintained it is not reasonable nor logical to determine or assume the "Root-Cause" of failure.
All of the posts are excellent information and should be considered.
Register to Reply 7 comments
obouill (1); PeterT (1); PWSlack (3); SHOCKHISCAN (1); Yahlasit (1)
