No matter what 2 digit number you pick, deducting its two component numbers will produce a number divisible by 9. Since the maximum answer you can get by doing this is 81 you will find that at closer inspection every number that is divisible by 9 up to and including 81 has the same symbol
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
I did it once and was very impressed....so impressed I did it again which is where the illusion let itself down It was the same symbol. Third time confirmed my suspicions.
A good magician will not perform the same trick twice because they rely a great deal on the element of surprise.
There was one like this a few years ago based on cards. It would predict the card you chose. Very clever, but as you say, after a few times, the magic was gone.
Well done!!!
