Previous in Forum: Cable Damage   Next in Forum: WiFi 802.11g Non-Overlaping Channels
IDMT Relay Setting
03/14/2013 2:32 AM
Dear friends,
We are having IDMT relay forgiving tripping command to SF6 breaker.Supply comes from EB is given to SF6 breaker & SF6 outgoing is connected to transformer,please any body give how the complete current & time setting calculation of IDMT relay.
Relay make:Alstom,CT sec:5A,Type:CDG61,
SF6 CT ratio:200:5,Full load current:1250 Amps
Transformer Rating:1.5MVA,11KV/0.433KV,Ipy:78.73Amps,Isy:2000 Amps,
Please ask any other data you need,
RK
Re: IDMT relaysetting
03/14/2013 7:40 AM
Whether IDMT relay will serve for medium voltage circuit breaker(SF6 circuit breaker) ?
Good Answers: 131
Re: IDMT Relay Setting
03/14/2013 2:56 PM
You need to hire a qualified engineer to do a proper relay coordination study for your application. We can't see your system, don't have drawings to show how it is configured, don't have information on fault current values, or what relay (manufacturer, model, etc.) you have, or what standards apply in your particular situation or locale. Do you really think you should rely on unknown forum participants to do an engineering study or specify protection parameters for you???
Good Answers: 19
03/16/2013 12:01 AM
Settings can be suggested, But some more information such as load details, any motor loads, highest motor capacity with starting time, starting current details are required.
Ramesh,Freelance Electrical/automation Consultant
03/17/2013 10:15 AM
with the given data u can set 2 Amp or 40% secondary current.. you should calculate time setting considering up stream relay for relay coordination.. Atleast 250ms time interval.
Muthuvel (1); PeterT (1); ramvinod (1); sethuamanj (1)
