Previous in Forum: What would you do with a 77 KW induction heater rig?   Next in Forum: Are There Any Valves "Made in USA"
API 5L Pipe Spec Clarification
03/17/2013 5:28 AM
Hello,
Pipe Standard:- API 5L/ ISO 3183
Table-1 Pipe grades,Steel Grades and acceptable delivery conditions
Pipe Spec:- PSL-2, L450 Q or X65 Q
PSL- Product Specification Level (Level-1 and Level-2 available in API5L/ISO3183)
65 = 65000 Psi or 65Ksi
Q = Quenched and Tempered
By the way,What is this L450 ? From where I can get the defenition of this term ?In API 5L/ISO 3183 where it is mentioned?I am confused...
Thanks in advance
Re: API 5L Pipe Spec Clarification
03/18/2013 6:03 AM
Quite interesting!!!I have explained most of the data after extensive research!!!I need small help to know about a silly thing L450!!! Where is CR4's great gurus?? Gurus pls help me...........
03/19/2013 4:18 AM
AP#1,
let me have a go.
guess 450 stands for the value of specified minimum yield strength in SI unit
450Mpa = 65ksi
03/19/2013 5:19 AM
Thanks Jaycee,you are right.After a long search in the API 5L, I found it in table-7.
