Previous in Forum: API 5L Pipe Spec Clarification   Next in Forum: Reboiler Manway Plate
15 comments
Good Answers: 122
Are There Any Valves "Made in USA"
03/18/2013 6:40 PM
Does anyone have a source for high quality, high performance "Made in USA" gate valves w Hand Wheel Operator? 150 WCB, RF (Raised Flange), BB,
Thanks,
Jim
Re: Are There Any Valves "Made in USA"
03/18/2013 7:17 PM
Good Answers: 122
03/20/2013 1:33 PM
Thanks a bunch everyone!
I really appreciate the help!
Good Answers: 21
03/18/2013 8:05 PM
Mueller, Chattanooga, TN
03/19/2013 4:35 AM
No, not really.
Good Answers: 12
03/20/2013 1:03 AM
Be careful what you ask for. There are cities in both Japan and Russia that go by the name of Usa. Some early manufacturing that came from Japan were labeled as "Made in USA" and it was perfectly legal.
And there are also cities in the U.S. with the name 'China' in Indiana, Michigan, Maine and Texas.
But to answer your question...sorry no.
Good Answers: 21
03/20/2013 1:45 AM
Beg to differ, as I stated Mueller Company has plants in Chattanooga, TN and Albert-ville, AL. Both sites make various cast iron and brass valves from 3" up to 60". There are others here in the States that make brass ball valves and such as well. Not hard to find. There is a place in La Porte, In that sells to contractors and stocks U.S. Made and overseas materials for contractors, so you have a choice. Look around easy to find.
Location: Wake Forest, NC USA (in Central NC, God's country)
03/20/2013 1:13 AM
You might try going here: http://flowserve.com. They have valves for nearly any application.
“Better to remain silent and be thought a fool than to speak out and remove all doubt. - Abraham Lincoln”
Good Answers: 25
03/20/2013 7:02 AM
Flowserve Corp have collabration with Larsen & Toubro Ltd.India, they make "Audco" brand valves for various industries. These valves are well known for their quality. Flowserve are still making valves in U.S. You can approach them for your requirements.
03/20/2013 7:58 AM
Ross Valves in Troy, NY
http://www.rossvalve.com/
Good Answers: 179
03/20/2013 8:58 PM
Ross Valve are primarily globe valve bodies to produce PRV's, flow control values and altitude values, etc.
To the best of my knowledge they do not manufacture gate valves.
03/20/2013 9:03 AM
What size are you looking for? This company makes them in Sartell, Minnesota for the water and sewage treatment facilities:
De Zurik
(320) 259-2000
Good luck
03/20/2013 9:43 AM
Copes Vulcan Erie Pa
Good Answers: 179
03/20/2013 9:00 PM
For the water industry, the two largest gate valve manufacturers are Mueller and Clow.
03/21/2013 4:01 AM
Hi, as I've just got back into supply / materials cataloguing after a 4 year break - [not of my choosing] you should give a little more detail as to valve size, style, usage, material etc.Can the hand wheel operation be changed to powered? Where is the valve to be located {don't say the obvious, a pipe string} etc.
Good Answers: 117
03/21/2013 6:30 AM
FMC.
They make all sorts of valves for the oil industry.
Register to Reply 15 comments
anicholas (1); Bart@ (1); brich (1); CaptMoosie (2); daffy (1); fixitorelse (2); lyn (1); Phil D. (1); PWSlack (1); rhandwor (1); SHOCKHISCAN (1); suresh sharma (1); terrapin (1)
