Previous in Forum: ASME Section VIII Hydrostatic Test, Pressure Gauge   Next in Forum: Combining ISO 16949 After Implementing TQM
CPK
03/21/2013 10:16 AM
Will I ever be able to achieve a 1.33 CPK when I always have to run to one side of the mean?
Anonymous Poster #2
Re: CPK
03/21/2013 10:26 AM
Anonymous Poster #3
Re: CPK
03/21/2013 11:56 AM
Very helpful, AP#2.
Here - this may be of use: Process capability
Re: CPK
03/21/2013 1:17 PM
Thanks, that verifies what I was thinking.
Good Answers: 151
Re: CPK
03/21/2013 12:54 PM
Calculations commonly used for Cpk assume that the process variation has a normal distribution which is symmetrical about the process mean. I your case, where you must maintain the process on one side of the mean, the process does not have a normal distribution. In this case the calculation of the process capability must be calculated from the the probability density function of your particular process. This will require someone with more expertise in statistics than me.
Good Answers: 183
Re: CPK
03/22/2013 5:40 AM
Could you better explain what you have as process since if you have a mean value you have values on both sides of it.
The CPK gives an indication about the eccentricity of the distribution and is a measure of the probability to have values out of tolerance interval even if the distribution is narrow with respect to the tolerance field. It does not loose its meaning even if you work on one side since the eccentricity can be such that values come out of range.
The CAM measures how narrow the distribution is with respect to the whole tolerance field. Both parameter indicate the risk to get scrap.
Anonymous Poster (2); gringogreg (1); nick name (1); Quality Girl (1)
