Previous in Forum: Just Lost a GT   Next in Forum: How Did All of You Start Your Journey in Electrical n Electronics World?
DC 110V 15 A Charger
03/23/2013 2:33 AM
dear engineers,,
pls let me know where do i get DC110V 15A or 10A portable DC charger?
it should be portable, bcz to carrey from one location to another,. at present we got kirloskar make charger. but is bulky to move. for emergency need to have one.
DC supply for controle, and for protection. I am near to Bangalore.
Re: DC 110V 15 A Charger
03/23/2013 10:58 PM
What is the battery chemistry?
What kind of charging: Fast, slow, float, combination?
Is battery balancing an issue? If so, how many batteries?
What is the AC power/frequency in your country?
How much babysitting do you want to do? Meaning, you may be able to adapt a CC/CV programmable power supply for the task.
Just one? Any possibilities of a backup?
Environment the charger will be in?
How long should the charging take? 3 hrs? 15 hrs? Ballpark?
These are just some of the quesitons that box the problem so it's solveable.
03/24/2013 12:17 AM
just google it and many will come up
I cant paste the link,the site wont let me paste.
http://www.amazon.com/Stanley-BC1509-Automatic-Battery-Charger/dp/B001U04MSU
ok here is only one link
03/24/2013 2:34 AM
The site has a wierd method for posting links. Paste the link like you did. Highlight it and THEN click the icon with a chain in it. You will be offered the opportunity to make it look like I did. I had some wierdness that the site kept typing in the link font, but highlighting the text before and "remove link" fixed it.
Battery Charger
03/24/2013 11:32 AM
Most automotive shops have a portable charger with 2/10 /boost switching 110 volts, also any electrical motor shop also has variable units- price range $ Cdn from 39.95 to 200.00
03/24/2013 1:10 PM
More i think about it,are you a guy,I never heard of a guy not knowing things like were to get a battery charger.
You must have found one by now., Good luck. and lets hope that you never will have to put a new crank shaft in .
03/25/2013 10:28 AM
An alternative use for a battery charger is for rust removal, Most, if not all, newer chargers are set up in such a way that they shut off when the battery is fully charged. The older style continues to put out a steady charge. If one were trying for rust removal, where could one get a new charger without the automatic shutoff? For some people this would be more useful.
Australia - Member -
07/27/2016 8:03 PM
Old school, I used battery chargers in series until my angle grinder went fast enough to use a Lambs wool Buff on my car.
Also saved money when doing rust hole repairs to smooth out the filler with a steel grinding disk (Death wheel).
smokingwheels
Register to Reply 7 comments
conntaxman (2); cuchullain3 (1); Hugh Sutherland (1); KeepItSimpleStupid (2); smokingwheels (1)
