Previous in Forum: Travels with Vista   Next in Forum: AutoCAD Dimesion overrides.
AutoCAD file size
05/29/2007 12:10 PM
I have been doing engineering models with Inventor 9. Within Inventor, after completeing the model, I then create an Inventor drawing and then save a copy of it as a dwg. file to put into an AutoCAD title block (AutoCAD 2005) and send off to the client. (They only have AutoCAD but the drawings are very dificult to achieve with that software.) The problem is that every now and then, the AutoCAD file as the finished drawing, jumps from a multiple KB file size to a multiple MB file size. The drawings and models are very simple and pretty much the same. They consist of an outer ring, a concentric center ring and fins joining the rings around the diameter. It looks kind of like a turbine engine. The only thing that changes between drawings is the diameter of the rings and the number of fins around that diameter. The file size increase is very random with no pattern at all. You would think that the larger diameters with a larger number of fins would equal a larger file size, but it seems to have nothing to do with that. The process of converting to a dwg. file is consistent from drawing to drawing so I can't see how that could be the issue. I am stumped. If this makes any sense to you at all, would you have any theories as to why this happens and what can be done?
If it can be imagined, it can be.
Popular Science - Weaponology - New Member Engineering Fields - Aerospace Engineering - New Member Hobbies - Model Rocketry - New Member United States - Member - New Member
Re: AutoCAD file size
05/29/2007 2:38 PM
Off the bat, I would recommend adding the title block with Inventor, then saving as dwg, and cut out the AutoCad transfer.
I found Inventor great overall, but it does have quirks with exporting/importing, and some other things. Version 10 improves on some of that. I haven't used the newest version, but upgrading might smooth things out, if you have some extra money you want to throw around. I have to use Pro/E now and hate the interface!
If you want to keep your current process, here are some things to look at. Check the output settings in Inventor and make sure you are 100% consistent from drawing to drawing. There are settings that keep 3D data when exporting 2D drawings that will increase file size. There are various 2D settings that depend on what you do while in 3D mode. Unless you are 100% consistent with your modeling process, some of those might be changing. Make sure everything is on one layer. In AutoCad, make sure you are adding the title block to the same layer as the drawing, or at least stay consistent with layer settings if you want it in a separate layer. Depending on how you are doing the importing and title block, you might be accidentally adding layers that would increase the file size. Check that the drawing sheet size isn't changing somewhere along the line.
It has been a while (years) since I've used 2D anything, but I seem to remember there being a line height sometimes included when data from a 3D program was imported. It would show up as one layer, but multiple heights. That would definitely add to the file size and might be easy to miss. There is some way to force everything onto one plane, or project onto one layer, etc. that fixed it. You also might be getting multiple instances of each line that would multiply the file size. Some obscure setting might cause something like that.
With picture output from Inventor, the exported file size depends on the size of the model window when you tell it to output. I don't see any way that a dwg output would do the same, but checking that dumb things like always having the window maximized are consistent might surprise you. And frustrate you, make you curse Autodesk, your computer, the world, etc for the stupidity of it and the time it cost you :)
Good Answers: 94
05/30/2007 8:52 AM
Just adding to Butchers comments, once you have the 2D AutoCAD file you can use the 'purge' command to remove any redundant layers, linetypes, dimstyles etc. If you need to upgrade Inventor you can now get an Inventor LT version which is substantially cheaper, I think its main limitation is that you can produce parts but not assemblies.
05/30/2007 11:33 AM
If you update Inventor to 2008 you can save in the .dwg instead of .idw file type, keeping the information native to AutoCAD. We use it because some of our customers and outsourced vendors have AutoCAD 2000-2008.
Register to Reply 3 comments
Anonymous Poster (1); Butcher (1); Nigh (1)
