In ETAP 7.0 you have to select a value for the following parameters for an overcurrent relay:
1) pickup range 2) pickup 3) Time dial 4) Relay Amps. 5) Prime Amps.
They're located at the overcurrent relay editor at the OCR tab. I've read the help menu, but it doesn't explain the definition of these parameters.
Can anyone explain what is their meaning?
Regards
