Previous in Forum: Global Internet Slows After 'Biggest Attack in History'   Next in Forum: The Amazing Mind
Good Answers: 94
Measuring Length of Strip
03/27/2013 1:37 PM
I have the occasional need to measure lengths of braze material from a roll, probably several metres at a time. I'm sure I've seen devices where you pull the strip over a roller which measures the length, like a miniature surveyors wheel, but can't find this on-line. I expect I'm not using the right search terms. The braze material is a silver/copper alloy & is quite soft so the roller pressure must be light to avoid marking. As this would not be used often I don't want to spend a lot either, can anyone point me in the right direction?
Good Answers: 125
Re: Measuring length of strip
03/27/2013 2:16 PM
You could probably use a drafters wheel.
Try this.
Re: Measuring Length of Strip
03/27/2013 2:19 PM
Or a measuring wheel.
4" Measuring Wheel ‑ Single$35.00
Good Answers: 104
03/27/2013 4:29 PM
I was looking for one like the big box stores use to measure rope and cable. Here's something similar . Google 'wire measuring wheel' or 'rope measuring wheel' for more. Metric?
Good Answers: 104
03/27/2013 4:39 PM
This one's at $5.99 on eBay right now
Good Answers: 94
03/28/2013 6:30 AM
Some good suggestions here, thank you all. Now that I have that right search terms I have found a couple of promising looking devices that I could probably adapt. This one looks like it has a wide roller but hard to tell from the picture. This one is cheap enough to buy & play with.
bigg (2); lyn (1); Nigh (1); WJMFIRE (1)
