Previous in Forum: Electrical Inverter   Next in Forum: Reactive and Under Voltage Relation?
Which Capacity Diesel Engine I Buy Kindly Suggest
03/28/2013 11:49 AM
i have to install a dg set 3 phase in a building.it got 16 nos flats each flat load is 22.5 kw single phase load in each flat . means 360 kw single phase load in total.wat capacity engine i have to buy.360 kw load is single phase & engine to buy is three phase.
Thanks & pls reply
Re: which capacity diesel engine i buy kindly suggest
03/28/2013 11:55 AM
That means 5 loads are on two phases while the third phase carries 6. So simple arithmetic means with no diversity 22.5kW x 6 x 3 phases = 405kW, giving 10% capacity increase for another 2 flats. However, diversifying the loads will reduce this demand by a factor that the forum cannot see.
Alternatively, if all loads are on one phase, then a generator of 22.5kW x 15 x 3 = 1MW+ is needed to support it with no spare capacity, with two phases doing nothing. However, diversifying the load will reduce this demand by a factor the forum cannot see.
03/28/2013 10:51 PM
but the current carrying in three phase supply is 2 times & in the case of single phase is 4.5 times.means 410 kw is 1815 amp for single phase. then from whom i can decide my diesel engine by kw or by amp.
03/29/2013 6:10 PM
Well, the starting point is how the load is distributed across the phases, about which the forum knows nothing.
Re: Which Capacity Diesel Engine I Buy Kindly Suggest
03/30/2013 9:08 AM
How did you evaluate the load in each flat,did you consider diversity in each flat as well as overall diversity?.
pnaban
ashutosh goyal (1); pnaban (1); PWSlack (2)
