Previous in Forum: RAID Controller and SSD Drives   Next in Forum: Contracting Management
14 comments
What is the Secret Message?
04/06/2013 3:54 AM
User-tagged by 1 user
Re: What is the secret message ?
04/06/2013 4:36 AM
This time we used dot codes for each alphabet character. A little harder perhaps. Well done if you were able to solve it.
Courtesy of FBI.gov
04/06/2013 5:34 AM
Now try this one ....
EMUFPHZLRFAXYUSDJKZLDKRNSHGNFIVJ YQTQUXQBQVYUVLLTREVJYQTMKYRDMFD VFPJUDEEHZWETZYVGWHKKQETGFQJNCE GGWHKK?DQMCPFQZDQMMIAGPFXHQRLG TIMVMZJANQLVKQEDAGDVFRPJUNGEUNA QZGZLECGYUXUEENJTBJLBQCRTBJDFHRR YIZETKZEMVDUFKSJHKFWHKUWQLSZFTI HHDDDUVH?DWKBFUFPWNTDFIYCUQZERE EVLDKFEZMOQQJLTTUGSYQPFEUNLAVIDX FLGGTEZ?FKZBSFDQVGOGIPUFXHHDRKF FHQNTGPUAECNUVPDJMQCLQUMUNEDFQ ELZZVRRGKFFVOEEXBDMVPNFQXEZLGRE DNQFMPNZGLFLPMRJQYALMGNUVPDXVKP DQUMEBEDMHDAFMJGZNUPLGEWJLLAETG ABCDEFGHIJKLMNOPQRSTUVWXYZABCD AKRYPTOSABCDEFGHIJLMNQUVWXZKRYP BRYPTOSABCDEFGHIJLMNQUVWXZKRYPT CYPTOSABCDEFGHIJLMNQUVWXZKRYPTO ETOSABCDEFGHIJLMNQUVWXZKRYPTOSA FOSABCDEFGHIJLMNQUVWXZKRYPTOSAB GSABCDEFGHIJLMNQUVWXZKRYPTOSABC HABCDEFGHIJLMNQUVWXZKRYPTOSABCD IBCDEFGHIJLMNQUVWXZKRYPTOSABCDE JCDEFGHIJLMNQUVWXZKRYPTOSABCDEF KDEFGHIJLMNQUVWXZKRYPTOSABCDEFG LEFGHIJLMNQUVWXZKRYPTOSABCDEFGH MFGHIJLMNQUVWXZKRYPTOSABCDEFGHI ENDYAHROHNLSRHEOCPTEOIBIDYSHNAIA CHTNREYULDSLLSLLNOHSNOSMRWXMNE TPRNGATIHNRARPESLNNELEBLPIIACAE WMTWNDITEENRAHCTENEUDRETNHAEOE TFOLSEDTIWENHAEIOYTEYQHEENCTAYCR EIFTBRSPAMHHEWENATAMATEGYEERLB TEEFOASFIOTUETUAEOTOARMAEERTNRTI BSEDDNIAAHTTMSTEWPIEROAGRIEWFEB AECTDDHILCEIHSITEGOEAOSDDRYDLORIT RKLMLEHAGTDHARDPNEOHMGFMFEUHE ECDMRIPFEIMEHNLSSTTRTVDOHW?OBKR UOXOGHULBSOLIFBBWFLRVQQPRNGKSSO TWTQSJQSSEKZZWATJKLUDIAWINFBNYP VTTMZFPKWGDKZXTJCDIGKUHUAUEKCAR
NGHIJLMNQUVWXZKRYPTOSABCDEFGHIJL OHIJLMNQUVWXZKRYPTOSABCDEFGHIJL PIJLMNQUVWXZKRYPTOSABCDEFGHIJLM QJLMNQUVWXZKRYPTOSABCDEFGHIJLMN RLMNQUVWXZKRYPTOSABCDEFGHIJLMNQ SMNQUVWXZKRYPTOSABCDEFGHIJLMNQU TNQUVWXZKRYPTOSABCDEFGHIJLMNQUV UQUVWXZKRYPTOSABCDEFGHIJLMNQUVW WVWXZKRYPTOSABCDEFGHIJLMNQUVWXZ XWXZKRYPTOSABCDEFGHIJLMNQUVWXZK YXZKRYPTOSABCDEFGHIJLMNQUVWXZKR ZZKRYPTOSABCDEFGHIJLMNQUVWXZKRY ABCDEFGHIJKLMNOPQRSTUVWXYZABCD
Location: OHIO, tri-State design and installation, and travel nationally and consults also are international
02/16/2014 7:40 AM
I like ranch on that salad
Simply choose your utility supplier contracting WITHOUT BROKERS and opt-out of community aggregations for free choices.
04/06/2013 7:50 AM
That is off the Kryptos Sculpture
Part I: Between subtle shading and the absence of light lies the nuance of iqlusion
Part II: It was totally invisible Hows that possible? They used the Earths magnetic field X
The information was gathered and transmitted undergruund to an unknown location X
Does Langley know about this? They should Its buried out there somewhere X
Who knows the exact location? Only WW This was his last message X
Thirty eight degrees fifty seven minutes six point five seconds north
Seventy seven degrees eight minutes forty four seconds west ID by rows
Part III: Slowly desparatly slowly the remains of passage debris that encumbered the lower part of the doorway was removed with trembling hands i made a tiny breach in the upper lefthand corner and then widening the hole a little i inserted the candle and peered in the hot air escaping from the chamber caused the flame to flicker but presently details of the room within emerged from the mist X
Can you see anythingq
As far as I know, nobody has cracked the 4th section yet.
04/06/2013 8:36 AM
Here's a toughie...
XUKEXWSLZJUAXUNKIGWFSOZRAWURO RKXAOSLHROBXBTKCMUWDVPTFBLMKE FVWMUXTVTWUIDDJVZKBRMCWOIWYDX MLUFPVSHAGSVWUFWORCWUIDUJCNVT TBERTUNOJUZHVTWKORSVRZSVVFSQX OCMUWPYTRLGBMCYPOJCLRIYTVFCCM UWUFPOXCNMCIWMSKPXEDLYIQKDJWI WCJUMVRCJUMVRKXWURKPSEEIWZVXU LEIOETOOFWKBIUXPXUGOWLFPWUSCH
04/06/2013 8:58 AM
So tough it has yet to be solved. It is one of the Feynman Cyphers.
04/06/2013 9:14 AM
Here's an easy one....
04/06/2013 9:52 AM
I think there is an error with the 2nd charactor on the 2nd line, it should be the eagle. If so, then it reads :
You search to solve can you solve this though.
04/06/2013 10:02 AM
Well done....I have no clue on yours.....
04/06/2013 10:26 AM
+1 +1
04/06/2013 9:10 AM
Try this one, shouldn't be too hard, I just came up with it :
DCQ CTA ZWUFP FUWH, Y AMLN HWAC HT VR. MTTUR.
Good Answers: 61
04/06/2013 9:13 AM
Strewth! You people have an awful lot of time on your hands! Any out there like to help me plaster and paint my kitchen walls?
04/06/2013 9:46 AM
Sorry, that's why I rent....got tired of being a slave to my property.....Unless the perks outweigh the mundane nature of home maintenance, and you have an airplane...?
Good Answers: 27
04/07/2013 8:45 AM
They are probably just doing their morning exercise routines, polishing and honing on their abilities to prevent the early onset of DEMENTIA ... :) :/
vsar
Register to Reply 14 comments
energyconversion (1); JP76 (1); JPool (6); SolarEagle (5); vsar (1)
