Friend,
what is the purpose of diffuser in the pipe line at its outlet? In the below figure if i maintain same flow and same inlet pressure will my pressure difference (drop) between point A & B change for the cases of with and without diffuser? Assuming the total length in both cases are same and the diameters are same till diffuser.
If not then why the flow rate increases in the duct having a diffuser compared to the one without diffuser?
