Previous in Forum: Difference Between ASTM A106 and API 5L   Next in Forum: Seeds Problem in Glass
Wear Protection in a Float Glass Manufacturing Unit
04/13/2013 3:40 AM
Dear Friends,
If some of you know or have worked in a Float glass manufacturing unit.
can you guide on what applications require wear protection or maintenance.
interms of welding, coating etc..
For instance :
1) Wear of Glass crushhing hammers
2) Wear of anneling Lehr Roles
3) Repair of Steel at Heat treat ment furnances
etc...
regards
Sanjay
Pathfinder Tags: Float Glass
Re: Wear Protection in a Float Glass Manufacturing Unit
04/13/2013 1:39 PM
Perform a search for "PPE requirements of the float glass industry".
I'm sure there will be information there.
04/14/2013 12:47 AM
Dear Iyn, Thanks for your answer, but i refer to Wear protection ...that is metal / mechanical wear.and tear .....need for hardfacing or ceramic coatings etc....
Good Answers: 25
04/14/2013 3:15 AM
What a confusion! you should have written surface wear and tear of steel etc.
04/14/2013 4:08 AM
:D
Register to Reply 4 comments
lyn (1); sanjayb (2); suresh sharma (1)
