Previous in Forum: Dimmer System   Next in Forum: Chip Datasheet
Need RF Transceiver for 200 m, 500 m,1 km Range
04/19/2013 11:36 AM
Dear friends,
Please suggest RF modules for or 200 meter,500 meter,1 km range .Low cost module is preferable..
Thanks in advance.
Re: Need RF Transceiver for 200 m, 500 m,1 km Range
04/21/2013 3:43 PM
There are hundreds and hundreds of products out there, from complete programmed modules to single chips operating on numerous frequencies.
If you don't know what you are doing and don't have the skills or equipment to program a chip then I suggest you just buy a complete module. They are more expensive but unless you know what you are doing and you want to build hundreds or more, the kitset or single chip-based transceivers can be very difficult and time consuming (expensive) to get working as a complete system.
Try an internet search of "rf transceiver supplier".
04/23/2013 5:33 AM
Hello.
I have completed TRX module. Band 2.4-2.48GHz. Transmitter power 100mW, reciever sensitivity -110dbm. Module contain own atmega 164 controller and schematic of power managment. Internal chip antenna and we can connect external antenna. Programmable data rate from 1.2 to 500 kBaud. SPI inteface and Data Tx-Rx interface. We are tested communication distance in open feeld 1km. Size 35x25x7mm.
Regards,
CR4 Admin - Removed Email and Price
No advertising is allowed on CR4 outside the commercial space forum.
Register to Reply 2 comments
