Previous in Forum: Water Flow Control   Next in Forum: Grounding of 1C Unarmored Cable
One Single Phase kWh Meter to Measure 3 Phase Power
04/20/2013 10:44 AM
Hi Engineers,
I have a mini hydro project. It has a 3 phase balanced alternator, low voltage of 24 -36 volts to charge battery via rectifier and for resistive loads. How can I measure the power by using one single phase household kwh meter ? Where may I get the wiring diagram? Many thanks.
Re: One Single phase kwh meter to measure 3 phase power
04/20/2013 11:04 AM
Depends on the meter design....and whether the load is balanced...
http://en.wikipedia.org/wiki/Blondel's_theorem
04/20/2013 12:03 PM
You will have to reconfigure your alternators three phases into a "Zig Zag" configuration so that it is putting out single phase power from there your wattmeter will work just fine but your system will now be a 48 - 72 volt output.
A Zig Zag is basicly a delta configuration with one phase shifted one way or the other turning the triangular configuration into a roughly Z shape.
The second option is you just measure one phase and multiply your readings by three assuming that your load is reasonably balanced between the phases.
