Previous in Forum: One Single Phase kWh Meter to Measure 3 Phase Power   Next in Forum: DC Motors
10 comments
Grounding of 1C Unarmored Cable
04/20/2013 11:41 AM
Please some one clear my dought.....
How can single core un-armoured cable can be grounded.....??
Since single core cable should be grounded at one end to avoid circulating current......??
Re: Grounding of 1C unarmoured cable
04/20/2013 12:11 PM
Attach one end of it to ground (earth).
I suspect more context is needed for this question.
04/20/2013 12:35 PM
Nah, we'll just get a wide variety of WAG, as we normally do. We'll probably collect a few that will deliberately misapply the tiny amount of information we do have. (Just use a pneumatic circular grinder. The burrs on the conductors will be ground off easily.) Then somebody will make a timely joke on a reply and the fun will begin.
04/20/2013 12:41 PM
I almost forgot, somebody will cite along the way some Engineering reference that the OP should already have to be doing their work. This may or may not generate a brief firestorm of safety concerns. As usual safety issues will lead to complaints of the "nanny state". A pedantic flurry will ensue until this vacuous thread dies.
Re: Grounding of 1C Unarmored Cable
04/20/2013 5:43 PM
Using the correctly-sized cable lug, correctly-fitted onto a correctly-sized terminal. If in doubt, consult a qualified Electrician locally.
Good Answers: 42
04/20/2013 11:40 PM
It seems to be:
SHIELD [if it is a shielded cable] should be grounded at one end to avoid circulating current..
Julius
Good Answers: 170
04/22/2013 5:43 AM
Oh! How naive you are!
When anyone talks about (intentional) grounding of a cable, it generally is understood that the cable's shield or armour is grounded intentionally, for reasons of safety, et al. It could be at one end or both ends, each method having their own merits & demerits. But, this applies to "armoured cables" only.
And, your bold lettered quote is wrong. It should read" "Since single core cable's SHIELD OR ARMOUR should be grounded at one end....."
So, unarmoured cables need not be grounded.
One exception could be that if the single core unarmoured cable itself is used as a grounding conductor or protective conductor, in which case, obviously the conductor core of the cable should be grounded at BOTH ENDS.
Good Answers: 42
04/22/2013 8:28 AM
Sorry electricalexpert65."But, this applies to "armored cables" only." Medium Voltage cable-from 5 kV-is always shielded and- usually- non-armored.
Julius
Good Answers: 170
04/22/2013 8:42 AM
In your country you call it shield; here, in India, we call it Aromour.
04/22/2013 10:43 AM
So how do you know that the nomenclature of your country applies here?
Yet another WAG here.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
04/22/2013 10:55 PM
Shielding is to prevent interference, Armour is physical protection...
All that aside, the OP Specifically says that the Cable is un-armoured Single core and does not mention a shield...
So the Cable is either earthed at both ends (DB & Earth Conductor) as it is a Protective Earthing Cable or the original question is a "Nothing" question.
Regards,
Sapper
It's all about the Boom! - MythBusters
Register to Reply 10 comments
7anoter4 (2); electricalexpert65 (2); PWSlack (1); redfred (3); Sapper (1); Tornado (1)
