Previous in Forum: Grounding of 1C Unarmored Cable   Next in Forum: High Leakage Transformer
21 comments
DC Motors
04/20/2013 3:06 PM
What is the maximum available power rating in a DC motor?
Re: DC motors
04/20/2013 3:14 PM
"The maximum power of a DC motor is produced at the operating point that is defined by operation at half the no-load speed and half the stall torque."
This is the $2 answer....for a $10 answer, please deposit more money in your account.....
http://www.micromo.com/how-to-select-a-dc-motor.aspx
Re: DC motors
04/20/2013 3:18 PM
I want to know what is the maximum available size in the market
Re: DC motors
04/20/2013 3:38 PM
The maximum available size is much bigger than you are authorized to work with. Many traction motors found in locomotives are DC motors.
Re: DC motors
04/21/2013 12:05 AM
More than you can afford. i.e. the upper end of the range of power ratings of equipment available as 'build to suit', extends beyond the financial limits of any entity or group.
Re: DC motors
04/20/2013 3:36 PM
The biggest ones I have seen were used in our large coal mines and were around 3500 - 4000 horsepower but I have heard of far larger ones being used in steel mills.
Something on the order of 10,000+ peak HP.
Re: DC motors
04/20/2013 3:39 PM
Can i just get a catalogue of such motors please....it wud be really helpful.
Good Answers: 26
Re: DC motors
04/20/2013 3:55 PM
Re: DC motors
04/20/2013 4:06 PM
I wanted to replace 2000kW ac motor with DC motor. Is it available??
Re: DC motors
04/20/2013 5:12 PM
Telephone the AC motor's manufacturer and ask the question there.
Re: DC motors
04/20/2013 5:12 PM
What do you plan to gain by doing this?
The DC motor will cost more than its AC equivalent plus the control system to make it work will cost even more on top of that.
Re: DC motors
04/20/2013 4:08 PM
"The, "maximum available power rating in a DC motor" is only limited by your budget$$$.
Re: DC motors
04/20/2013 4:16 PM
Could you just confirm the availabilty with a catalogue? I just require for thesis purpose.
Re: DC motors
04/20/2013 4:24 PM
Who was your helper before you came here?
Can you search the internet? If you need help with this, just let us know, and somebody will show you the way.
BTW there is Global Spec, but the link doesn't show here.
Good luck, get going!!!
Re: DC motors
04/20/2013 4:29 PM
I found a maximum rating of only 1650kW DC motor ...and hence the question?
Re: DC motors
04/20/2013 5:10 PM
I guess you do not realize that often with motors the power unit of a watt is just impractical because of being too small. Convert your power requirement to horse power and look at what you can find.
Now go earn your thesis.
Re: DC motors
04/20/2013 5:20 PM
The thing is that there isn't a ready market for standard motors of that sort of size off-the-shelf. While they can, of course, be made to any size and shape, the concept of a catalogue is a non-starter as most motor manufacturers will build-to-order having gone through the proper sales-engineering process. No motor manufacturer worth his sales record is going to have a few motors of that size hanging around just to create a catalogue that will answer the questions of a thesis writer!
Potential customers who have a need for a motor of that size will go to several motor manufacturers with a detailed spec and, following a technical and commercial dance, will place an order with one of them. Delivery on that size of motor can be reasonably expected to be a number of months, while the motor is designed, the materials purchased, and its assembly diagrammed into the production lines among hundreds of others.
And it doesn't matter how many times the question is asked, either.
Re: DC motors
04/20/2013 4:20 PM
You could Google "2000kW DC motors" and see what comes up....
Then, since you now have AC, you could also Google "2000kW DC drives"....
Re: DC motors
04/20/2013 4:48 PM
Re: DC Motors
04/20/2013 6:23 PM
This is a late April 1st joke, right?
Good Answers: 181
Re: DC Motors
04/22/2013 9:00 AM
Good Answers: 116
Re: DC Motors
04/23/2013 5:28 PM
2000 kW submarine DC motor circa 1944. But I am sure it is not maximum possible.
http://www.hnsa.org/doc/fleetsub/elect/chap2.htm#2C
Register to Reply 21 comments
67model (1); Barchetta (1); Fredski (1); lyn (2); PWSlack (2); redfred (2); SolarEagle (2); tcmtech (2); TonyS (1); Tornado (1); truth is not a compromise (1); tushar_ggn (5)
