Previous in Forum: DC Motors   Next in Forum: LCI & Cycloconverters
10 comments
High Leakage Transformer
04/21/2013 12:25 AM
For high leakage transformer:
If the secondary coil will be short-circuited , then the flux in the portion of the core under the secondary will be nearly zero.
Can some one confirm the above statment !!
How come zero flux under a coil carrying a short circuited current ???
Good Answers: 11
Re: High Leakage Transformer .
04/21/2013 12:49 AM
Not true.
If the secondary is short circuited, there will be current in the secondary and in most cases, the magnitude of the flux caused by the current in the secondary will be only slightly less than the magnitude of the flux caused by the current in the primary.
04/21/2013 1:47 AM
'...the magnitude of the flux caused by the current in the secondary will be only slightly less than the magnitude of the flux caused by the current in the primary....'
But, of course the flux will not be nearly twice magnitude of the flux that would occur if the secondary were not there.... .....because the current in the short circuited secondary is in the direction such that it opposes changes in flux.
In short the magnitude at a certain time may only be slightly less, but in the opposite direction. Which, I think, is what the OP is after.
04/21/2013 1:54 AM
I'll confirm that the statement is valid with the right conditions.
Further:
All other things being equal, the flux in the portion of the core under the shorted secondary is closer to zero when:
-the secondary is a better conductor (frequency dependent)
-the transformer is has more leakage especially between the primary and secondary.
-the frequency is higher (with a caveat related to the better conductor condition above)
04/21/2013 10:11 AM
Actually the transformer works at 60 HZ frequency - Is a ferroresonance transformer with high leakage inductance.
04/22/2013 1:49 AM
....and this changes the scenario, how exactly?
oh, wait.
What is the thickness of a lamination in the core? Also, what it the effective cross sectional area and the length of the path through the core?
04/21/2013 10:40 AM
What is the point of operating a transformer in short circuit without its protective devices operating to stop it happening? Is this some kind of joke? Does the individual doing it have some sort of unfulfilled death wish?
04/21/2013 10:59 AM
Actually ferroresonant transformer works as a "Constant Voltage Transformer" - It is self protected against short circuit at its output - It passes only 1.2 -1.6 of its rated current at short circuit - and it can run short circuited for years without damage.
04/22/2013 4:20 AM
And why would one want to operate a transformer that isn't supplying power to its downstream load?
Good Answers: 11
04/22/2013 10:05 AM
Actually I designed a transformer for 100% impedance per the customer's specification.
The customer wanted to hipot cable and he wanted the current to continue after the cable failed. Customer never said if he wanted to make sure the cable had a positive failure or if he was trying to locate the failure.
04/22/2013 10:21 AM
Actually I want to design a Constant Voltage Transformer (CVT) 120V, 500VA - FERRORESONANT
Any special design equations or procedurs are available for that ?
Register to Reply 10 comments
Carl Pugh (2); Marzoky (3); PWSlack (2); truth is not a compromise (3)
