Previous in Forum: Impact On Production if Sizer Speed is Reduced   Next in Forum: Is it Necessary to Depressurize a Boiler Before Shutting Down for a Couple of Hours
Diesel Engine
04/22/2013 4:06 AM
Hai buddies I am facing problem in fuel line. it always getting air in filter housing and engine triping under speed,under voltage. how to fix this problem?
Re: diesel engine
04/22/2013 4:20 AM
Look for the leak, fix it and voila everything in order.
Re: diesel engine
04/22/2013 4:28 AM
Make sure that the tank is above the engine, so that there is a gravity feed to it. That way, the only way air will enter the feed pipe is if the tank runs dry.
Re: diesel engine
04/22/2013 4:35 AM
What about the leak? Now diesel will leak out!
Wish I could see them lifting up the tank!
Re: diesel engine
04/22/2013 4:40 AM
Well, it would show where the leak is! One can see it now:
Hai buddies I am facing problem in fuel line. it always getting diesel out of filter housing and engine triping low fuel level. how to fix this problem?
Re: diesel engine
04/22/2013 6:04 AM
Chuckles and has another beer!
Re: Diesel Engine
04/22/2013 10:37 AM
Find someone, someone who is local (meaning someone who can look at the fuel system) and has reasonably good vision and has just a smidgen of common sense and ask them for help.
It won't take an especially bright person to fix this minor air leak. Just some common sense.
Re: Diesel Engine
04/30/2013 5:21 PM
Apply air at very low pressure to tank breather and check for diesel leaking.
Register to Reply 7 comments
IdeaSmith (3); lyn (1); PWSlack (2); tasibrett (1)
