Previous in Forum: Hotwell Filling and Barring/Turning Gear Stoppage   Next in Forum: Extruded Aluminum Supplier
Getting a Vessel Seal Certified
04/27/2013 9:34 AM
I don't know if "Certified" the correct term, so i'll explain the situation.
The company I work for has been selling a device that we have installed in industrial piping and reaction vessels since around 1990. We use a custom designed seal and high temperature/high strength stainless screws.We have always rated this system at 1500 PSI and 200C. We test every unit at 2000 psi @ 200C before shipping. We supply drawings to the customer on how to machine their mating piece,
Our Seal vendor has provided pressure/temperature specifications and we have calculations for the strentgh of the screws.
We have a customer that is requesting a "certification to code" that the unit is OK for his application.
For this application, we will be using our sealing method to install the device into both a 150# and a 300# flange blind flange that will be modified.
The applicatoin is in The USA.
Any thoughts/advice would be appreciated.
thanks
Re: Getting a Vessel Seal Certified
04/27/2013 9:38 AM
04/27/2013 10:17 AM
If this is a one time thing it's not worth having your company certified(it's not cheap), just buy from a certified company wholesale and resell.....
http://www.physicsforums.com/showthread.php?t=291863
04/27/2013 12:15 PM
Can he get a certified shop to certify, (stamp), that one item?
Maybe a third party inspection service?
http://www.inspection-for-industry.com/pressure-vessel-certification.html
Register to Reply 3 comments
