Previous in Forum: Motor Bearings   Next in Forum: Reactance Measurement
14 comments
Protection Circuit?
04/30/2013 2:54 PM
I've lived a sheltered life and don't think I've ever seen sort of circuit before. Motor is 120V, several Amps. Are these components meant to be EMF protection or...?
Re: Protection Circuit?
04/30/2013 3:21 PM
Where did you find this weird circuit, a text book perhaps?
04/30/2013 3:56 PM
If the diodes were actually a pair of SCR then I could say that it is a block diagram version of a motor control.
04/30/2013 7:19 PM
True, true.
04/30/2013 9:58 PM
But it's weird, and in most places illegal, to have the switching components in the neutral line.
04/30/2013 10:02 PM
Never trust a block diagram presentation as the complete circuit.
04/30/2013 10:16 PM
Just as in speed races!
Good Answers: 32
04/30/2013 10:23 PM
It's what you might do in order to measure the motor current perhaps - use the diodes to limit maximum voltage across the shunt during startup. Is there something else that might be measuring across the resistor?
johny451
05/01/2013 8:09 AM
Actually, this comes from a circuit board I have. The motor's AC H line is switched on/off via a triac and microprocessor. The capacitor is (I think) a 0.1uF, the diodes are 1N4007 and the resistor is 220 ohm.
Traces DO extend from both sides of the resistor and these run across the board to a few other SMD components - one of which I suspect is a voltage regulator that appears to be related to the tact switches used for micro input. Interesting idea that motor current is monitored - I need to test for that.
Good Answers: 32
05/01/2013 8:51 AM
Ah that sounds like a zero crossing detection system. The 220 Ignore isn't small enough for current sensing.
johny451
Good Answers: 32
05/01/2013 7:05 PM
Ah - I love autocorrect (not). I sent the above from my phone. For "Ignore" substitute "Ohm".
johny451
05/01/2013 11:03 AM
Not sure what this is for with this being a pair of diodes. My only guess is that the four parts act as a non-linear current snubber to reduce EMI effects.
Good Answers: 444
05/01/2013 11:03 AM
It's most likely a snubber circuit to reduce the inductive spike from the motor back to the microprocessor when the SCR is commanded to turn off. My guess you found this inside a commercial apparatus or a household appliance that gets code approval as an assembly that normally doesn't get opened; i.e., labeled "No user serviceable parts inside"
Good Answers: 122
05/01/2013 1:20 PM
Ar you sure the circuit is drawn correctly?
It the top component a contact or a capacitor?
This circuit mimics a standard "bootstrap" used on TRIAC circuity to provide a path for the leakage current across the PN-NP junction that is always present when using TRIACS for voltage control.
05/09/2013 2:27 AM
Looks like a DC blocking circuit.
Gajanan Phadte
Anonymous Poster (1); gmphadte (1); jack of all trades (2); Johny451 (3); RAMConsult (1); redfred (3); SHOCKHISCAN (1); Tornado (2)
