Previous in Forum: Level Measurements   Next in Forum: ESD Valve
Specific Weight in ISA S750.1 for Control Valve Sizing
05/01/2013 2:20 AM
Sir, In ISA S75.01, for calculating Cv for liquid for mass flow rate, Specific Weight is required but unit of Specific Weight is required in kg/m3 but Specific Weight unit is N/m3. Kg/m3 is the unit of density so please tell me whether I should put value of density or I should multiply the densit with 9.8. Please advise.
I am man of simple taste.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: Specific Weight in ISA S750.1 for Control Valve Sizing
07/25/2013 10:47 AM
Try a simple "test case" with water as the fluid. The density of water is well-known, and the result should be easy to check because Cv is defined as the flow rate (in gallons per minute or water) at a constant pressure drop of 1 PSI.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
07/26/2013 5:34 AM
Hello tony sir,
I am very big follower of yours since when I started reading your book on Instrumentation. Everything is explained so clearly that I love that.
Sir, can you just provide me if possible your mail id so that i can ask queries directly to you.
i assure you i will not bother you frequently.
thanks.
Register to Reply 2 comments
