Previous in Forum: Measurement of Level for 100 % H2so4 Liquid   Next in Forum: Specific Weight in ISA S750.1 for Control Valve Sizing
Level Measurements
05/01/2013 12:34 AM
We want to replace float displacer as original float damaged and weight is 17kg in air RANGE IS
RANGE
1219MM
and new float weigh is 1.6 Kg . This is for oil and water process and as Safeguarding level switch On/ OFF and not analogue. The length of old is 120mm and new length of displacer is 122mm and range 1219mm. switch is Magnetrol and SS displacer
After replacing new displacer with 1.6 Kg and fluid SG 1.07 will make in change in tank level measurements ?
how to ensure the level is measured in tank as previous one. Please share you view
Re: level measurments
05/01/2013 3:30 AM
If the float is being changed like-for-like, then don't worry; chicken curry.
If the float is being changed for something else, then the instrument may need re-ranging, which is a job for an Instrument Technician at site.
Make sure the process is fully documented.
Is the instrument manufacturer on-board with all this or is it a home-brew-get-out-of jail-free sort of task?
05/01/2013 4:31 AM
PWSLACK,
Thanks for feedback. [ don't worry; chicken curry]
the concern the float weigh is different from new one, and it it bough from Magntrol factory is not home made.
How to re-range inst tech dose not know?
05/01/2013 4:41 AM
Follow the manufacturer's recommendations, either by telephone or in the manual. The manufacturer knows more about this equipment than any number of CR4 readers, so make that telephone call.
Re: Level Measurements
05/01/2013 10:13 PM
You don't mention which Magnetrol level instrument you have, so I picked one model at random, opened the manual
http://literature.magnetrol.com/5/48-635.pdf
and found this very clear and understandable statement:
Why don't you try looking up the procedure in the manual for your model?
Register to Reply 4 comments
Carl_E (1); Noor (1); PWSlack (2)
