Previous in Forum: PCS vs SIS   Next in Forum: Safety Valve, Relief Valve?
Needle Valve or 2-Way Manifold
05/08/2013 7:48 PM
Hi All,
What is preferred for pressure gauges a needle valve or a 2-way manifold? Is a manifold an over kill for a pressure gauge which in my case, is an accessory to a Pressure Transmitter measuring the same pressure?
Re: Needle Valve or 2-way Manifold
05/08/2013 8:11 PM
What color is the PT, red, yellow, blue, orange or black?
05/08/2013 8:26 PM
Both will isolate the pressure instrument. But gauge valves include multi-port and block and bleed styles suitable for calibration and venting. Does the installation warrant cal checks or venting?
05/08/2013 9:06 PM
They will require calibration at times.
05/09/2013 7:34 AM
Then the question is: do they need to be removed for calibration or is the procedure to be carried out in-situ? The answer determines the configuration of valves, manifolds, etc., that will be needed to accomplish the act.
Re: Needle Valve or 2-Way Manifold
06/23/2013 7:02 PM
Use a trumpet (manifold) valve.
Anonymous Poster (1); Carl_E (1); lyn (1); PWSlack (1); Steve Batey (1)
