Previous in Forum: OEM for Ball Cleaning System   Next in Forum: A Pneumatic Question
8 comments
Earthing During Welding
05/13/2013 2:36 AM
We all know that it is not good fabrication practice to provide loose or direct earthing to job. please suggest any alternative method to provide eathing during welding.
Pathfinder Tags: Welding
Re: Earthing during welding
05/13/2013 3:51 AM
Yep.
  • One could weld metals using gas burner jets instead, or
  • ultrasound, which is especially useful for plastics and for joining dissimilar materials, as is
  • solvent-weld, or
  • explosives.
  • Forge-welding using hammers is another method. Blacksmiths used to make swords that way and some probably still do.
  • Flame-spray welding is a good method of building up metal on worn parts, particularly those that can be rotated.
  • Thermit-welding is a great way of joining railway rails together in the field.
None of the above methods needs electrical contact with the work. Each has its application according to context, which is missing from the original post.
05/13/2013 8:39 AM
Welding process is GTAW & SMAW
05/13/2013 9:09 AM
Giving all the pertinent information in the original post ensures a quicker response from the forum with solutions and avoids the forum having to play "20 Questions" to elicit that information, with accompanying frustration/boredom/annoyance setting in, to the original poster's loss.
05/13/2013 8:34 AM
Provide a ground lug near the welding process.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
05/13/2013 8:39 AM
Please explain in details
05/13/2013 9:10 AM
Translation: weld a ground lug to the job, and then use that lug to attach the earth wire to complete the rest of the welding process.
Re: Earthing During Welding
05/14/2013 12:26 AM
Which polarity(+ve/-ve) should we earth when welding stainless steel,mild steel etc by using AC and Dc welding machine.
pnaban
Register to Reply 8 comments
lyn (1); pnaban (1); PWSlack (3); ronclarke (1); sachin salunkhe (2)
