Previous in Forum: Grounding   Next in Forum: Air Leak
19 comments
Good Answers: 16
Basic Vibration Analysis
05/24/2013 2:39 AM
Hello CR4,
I am getting ready to purchase a Fluke 805 to measure vibrations on medium speed diesel engine (900 rpm / 2000 HP). I am not formally trained in vibration analysis and I know there is abnormal vibrations present with this engine/generator.
This is being done on client request in order to have some recorded data for justification of disassembly and subsequent repair other than simply stating that the unit has high vibration.
It seems to me that the Fluke 805 is a good choice for this purpose as I can not justify purchasing the high end equipment that no doubt is over my head without formal training in the field of vibration monitoring.
If a member has experience with or preference to this or another similar handheld device I would appreciate your insight.
Thanks
Tim
Pathfinder Tags: vibration
Re: Basic Vibration Analysis
05/24/2013 9:19 AM
I have only had one training class on industrial vibration analysis, it was taught by Update International. The class was very good, if you can go to one of their classes you should learn enough to get started. If you cant, contact them and see what you can learn distantly.
Drew K
Good Answers: 16
05/24/2013 9:35 AM
Thanks for the contact, it appears to me from the 805 literature that its fairly straight forward for basic tasks.
I think its like most things today, to say it all depends on your budget and the criticality of work being done. For 50,000 I could have cases of high end equipment and miles of wires that I could never get a return on in my line of work...
Good Answers: 145
05/24/2013 5:33 PM
All of my vibration work was very different from your problem so I don't really know what I am talking about. With that disclaimer.....
It is interesting to try to come up with a comment for your question. Using an instrument to collect data seems like a very good step. But, what vibration is "good", what is "ok" and what is "bad"? If you have 10 of the same design and age engine then with good vibration instrumentation you could probably look at data and identify the source engine by the vibration signature. They would probably all be a little different and they would all change with age.
An off topic analogy would be my experience with the RF location system LORAN. Once upon I time I used LORAN signals and at times would monitor them daily. I used to freak out the Coast Guard by calling them up, telling them I was looking at their transmission and asking for confirmation that they switched from transmitter serial number X to transmitter serial number Y during the night. I would often get quickly transferred to the station commander. The commander understood that all transmitters were the same unless you looked carefully enough to see that they were not all the same. I would get my confirmation from him and that would be the end of it. The point is, with good measurements all the engines are different and that does not necessarily mean that there is a problem.
I guess my comments are:
1) Other than documenting "before" and "after" what will you do with your vibration data? Will someone try to use the data to "prove" a status of "good" or "bad" when all they really have is data that they are not qualified to interpret?
2) How do you "I know there is abnormal vibrations present" and why is that not good enough to justify the repair? How will you use this instrument to justify a judgement of "abnormal" that is more valid than the judgement you have already made?
3) Vibration is a tricky animal. Where and how you make your measurements will probably make a big difference in the data. You will have to be very consistent. You will possibly also affect the data in a "non bearing way" by any gaskets or bushings you replace. Note that vibration from other sources and vibration standing waves could easily make this task more tricky.
On the other hand using this instrument will probably be very interesting and could be very useful. Possibly very, very useful. Just be careful putting faith in an new instrument and technology unless you understand them.
Do you have any vibration measurement procedure standards or pass/fail criteria to use?
If anyone has experience using a similar instrument for a similar task then put much more faith in what they say than what I said. I'm just saying that it is interesting but you need to be careful.
Good Answers: 16
05/24/2013 7:52 PM
I agree with your take on this.
I do have two other like engines with roughly the same hours on them to compare data against, now the vibration can reportably be noted with the movement of a coffee cup on the desk...
I can not attest to this as I have not been on site yet, I understand this condition has existed for years now with no one making the commitment to take it out of service and seeing what in the world is going on. I am surprised there hasn't been a crank failure if its as bad as I have been told.
With companies such as this, with decisions being made from offices sometimes in another country, its necessary to state your case with data rather than old school such as THE DAMN THING IS SHAKING APART.
I have made it perfectly clear to my client that I doubt if I can narrow the source with my level of experience and also the seemingly very basic equipment such as this hand held Fluke, but I am hopeful that I can do enough comparison measurements and put the information together in such a way that we will get the green light for full examination and subsequent repair (also the approved AFE )
I'm not so worried about doing this, but still in hopes that some CR4 member may have had some experience with this measurement equipment to give a few pointers prior to me testing on shop equipment and then heading off to the site and figuring it out as I go.
The task is very interesting to me as its something I haven't done before.
Thanks a lot for your input, there is always something to be picked out of discussion on subject matter.
Regards
Tim
05/24/2013 11:30 PM
Just a bit of engine vibration I had with a Lima 90 tonne pin jib crane. I had 3 Cummins Big Boss NT460/s. Two of these engines ran flawlessly and one had a vibration that shook so violently that the radiator was literally shaken to pieces on a number of occasions in quick succession when there was no obvious external signs and the engine could not be taken out of service. I wish I had a vibration meter that I could identify what part was at fault.
I changed out different pieces until the engine ran at acceptable levels. The last component I removed turned out to be a water pump with a impellor that had been ground one on one quadrant side to fit the surrounds of the housing combined with a water pump bearing shaft that had a incorrectly machined that was in effect a 'cam' with off centre by 0.278" to the bearing axial axis which has the nearly 30 KG cooling fan hub acting as a fly weight eccentric vibrator. The temperature also ran a bit hotter than the others and higher than normal but not to 'Humphrey Watchdog' shutdown point. We were blaming the water loss due to leaking radiator and the additives 'Stopleak' for the temperature rise which is another point I should have picked upon but with everything going on and not actually doing the maintenance myself, I was not having all the facts given to me as a whole by my fitters.
I do not know how such a badly machined shaft got through Quality Assurance and assembly as the eccentricity was visually obvious and should have been picked up by the assembler. It was suggested that it may have been sabotage by a disgruntled worker.
This might not be of help but may be of interest.
Mechanical Solutions Company where 'There is no such thing as a PROBLEM, just an ISSUE requiring a SOLUTION'.
Good Answers: 22
05/24/2013 11:33 PM
Tim,
Study all you can, I've taken several courses. Making the measurements is fairly straight forward, but document locations carefully and take pictures. I can make measurements and I believe you can do the same with a little study. I am not good at balancing, however and some people just can and some cannot. That is more art than science. We had folks in some of our service shops that could guess the weight changes the first time on electric motors they were familiar with. They could never train others. My son is now in a plant that builds extremely large diesel engines and is a QC manager but he says the same thing, some people just cannot balance engines. It doesn't sound like you will get into the balance phase of things, but if you do and have problems, don't feel bad. If you do good, let everyone know about it.
Good Answers: 67
05/25/2013 2:10 AM
First my GA to BruceFlorida for detailed comment. Tim, you can also follow such simple step like marking GA for good comments.
In my experience, all the manufactures of this kind of instruments, provide consultancy, training and service to the customers besides selling their products. Contact few of them giving details of your equipment for their advice. Instruments for Vibration Analysis are more common for rotating centrifugal machines and less for recips like diesel engine. So be careful while selecting it for your application.
Good Answers: 16
05/25/2013 5:11 AM
WTF, go away
05/25/2013 10:28 PM
Suggest you look at:
www.vi-institute.org
05/25/2013 2:52 AM
The Fluke is good gear, as good as it gets in the price range. But not for IC engines. It works best for simpler machines, with several identical bearings for example. The complexity of the combustion, the tappets, valves, timing, injectors, pistons and everything else that moves, maybe 10,00 parts means its difficult to analyse this sort of machine with an 805.
Its all down to the interpretation. With respect to all the tech heads out there, we must remember that for many many years there was no analysis available apart from the engineer's ear and hand.
If you have severe vibration then one or more of the following must be true.
Misaligned shaft / out of center boss or rotating component / loose or damaged moving part/ badly worn bearings. Any of these can indicate imminent catastrophic failure. However, if its a trivial external part, like a loose circulation pump or sheet metal housing it may be noisy but not catastrophic.
I would get someone trustworthy to carefully examine and video all around, under and over the plant. Then do the thumb test with a rod of dowel and your thumb to the ear-flap and listen to the internal workings. Then you have a document of the outside (which you can review and compare with later similar documents) and an educated guess about whether the problem is internal and therefore more serious. With some practice you can use the rod to safely hear each journal, push rod tappet etc individually and you might be amazed how the sounds vary from a good tight unit to a worn out one.
I have never found an engine that does not respond to this sort of examination.Its cheap and takes seconds.
Like everyone else says, in order to make sense of your Fluke data you need to have a good control or two, which you can use use to subtract from the suspect machine and you are left with the error data. This only works well if the entire installation is standard. For example it might work with a standard production car or a generator providing there have been no modifications. Unfortunately if your suspect unit is different externally from the control, all you can do is a Fourier analysis and guess.
I would say the trained experienced engineer's opinion is much more use that the Fluke data, intriguing though it might be. The Fluke is really only for machines with a few moving parts, like compressors, saws, fans, or pumps. Nice gear though.
Good Answers: 21
05/25/2013 9:16 AM
Just a quick thought, does the manufacture have data on what you seek. Most manufactures have the testing and specifications for the units they sell. You might contact and get the engineering department and see what they have. Could save a hole lot of guessing.
Good Answers: 16
05/25/2013 2:41 PM
Ok guys thanks to most of you for your insight and good points, now its time to get to work here...
The choice is the basic Fluke due to the brand quality and ease of use, so the plan will be to carefully make same measurements at same points on all machines. Measurement points to be at most rigid areas such as block end plates, etc and also skid mounting points.
This hopefully will offer some usable data to satisfy client, then we will be free to actually resolve the issue with the old school methods.
Regards
Tim
05/25/2013 5:03 PM
There is alot of not very helpful advice here. You should really call an expert to help you weed through. My voice is just like everyone else here, you get to choose who you listen to.
The best advice I saw here was by Haroldus when he suggested misalignment, unbalance, bearings etc. but then he went off on comparing machines.
I don't believe you need to compare vibration from any other machine, that might give some indication on valves, pistons or other such parts, but not on what vibration analysis is usually used for.
Your problem could be bad compression or combustion on one (or more) cylinder, that could be seen by observing and comparing with other motors (but there are many other ways a mechanic could easily test for that.
What vibration analysis can tell you it can do just by measuring one engine, one part at a time.
I am far from a vibration expert, but what I do know is that you want to take vibration readins as close to the shaft or spinning part as possible, you want to read it on an x, y and z axis so you can see how much the shaft is moving in all three directions.
If your motor is driving a pump through a shaft and it is misaligned it can cause vibration up, down, side to side and back and forth along the shaft.
If your pump (or motor,or shaft coupling) is unbalanced it will usually show on only the x or y (perpendicular to the shaft).
If you have roller bearings with a damaged race, it will show as a number of knocks equal to the number of bearings per revolution as each bearing hits the spot. If there is a bad bearing, it will happen at a much higher frequency than the shaft speed rpm (because the small roller is spinning faster).
The point is, you need to take readings all over your machine on each spinnign part you think might be causing the vibration.
Then you need to analyze the data, and sometimes it is not any of the above (or other not mentioned problems with the motor/pump). It could be a harmonic with a support structure or pipe (but that is easily identified because it only happens at specific rpm).
Once you take the vibration data, you need to download it and examine it with software that will display the spectra of vibration. This can show in vibration acceleration, distance etc. It also shows the rpm the problem is at, and by knowing where the problem is at on the spectra you can pretty much (after referring to a book or years of experience) know what the problem is.
Drew K
Good Answers: 16
05/25/2013 6:36 PM
Very good take on the situation ... I realize its sort of like peeing in the wind, but the client wants some data, so thats what I will need to give him. But with looking at it from other posters point of view I can widen my view a little.
Regds
Tim
Good Answers: 145
05/25/2013 7:56 PM
Tim,
If you are able to please consider posting vibration data and equipment photographs after your testing. A number of us find your task interesting.
Bruce
Good Answers: 16
05/26/2013 1:34 AM
Will do Bruce, thanks.
Good Answers: 59
05/26/2013 11:10 AM
Hallo.
I come from instrumentation, so my comment meant to be understood that way.
The Fluke is a nice, simple to use device for what it is designed for. The documentation and data collection is good.
What it does not do, the necessary next step, to record crank angle and event relationship. Nor does allow recording of waveform, as its memory is too small for it. You have a magnetic pickup in the engine for rpm indicator, that can be used for crank angle measurement. And it is to show, When is something occurring.
Some possible examples, where this matters:
1,. It clearly indicates, which valve lifters do behave differently.
2,. It indicates, Which main bearing (considering centrifugal forces) may be outsize by now.
3,. If your water pump, or other accessories are geared, it is loud and clear in the waveform of a single rotation, that the trouble occurs according the gearing ratio.
When you decide to need this, do not hesitate to write.
Good Answers: 122
05/27/2013 9:50 AM
Tim,
The Fluke 805 meter is a good troubleshooting tool and can answer a lot of questions.
Regardless of what you discover/find with the meter and before you disassemble the engine; it would be worth you time and effort to look closely at the harmonic balancer on the engine.
Some (most) of the harmonic balancers are of two part design with a pliable dampening material sandwiched between the two mating surfaces.
The balancer is often damaged by personnel working on the engine such as changing of drive belts, adding/removing auxilliary equipment drive pulleys, etc.
In addition, radical impulse loading of auxilliaty equipment being driven by a pulley mounted on the balancer can also cause displacement of the two components of the balancer.
The resultant is that the outside part gets rotated independent of the inside part or gets "cocked" off center and therefore radically affects engine balance.
Some engines also have counter balance weights added to the flywheel and if the flywheel is removed or replaced, the weights can be moved off their original installation location and in some cases get completely knocked off during maintenance.
Normally this vibration condition is not present when the engine is new but appears after maintenance has been performed on the machine over a period of time.
Over the years I have found harmonic balancers are more often than not the cause of engine balance issues rather than an internal component.
I have occasionally found new harmonic balancers units right out of the box that are not in balance.
One other thing I would suggest is to check the engine crankshaft end thrust clearance as some are shimmed between the flywheel and crankshaft end and the shims can be left out/altered during maintenance.
Hope this helps.
Good Answers: 16
05/27/2013 10:29 AM
Your take on this is mine from the beginning, I have had this before on another EMD and it was in fact the Damper. These EMDs are fitted with a gear type damper that is fed with engine oil from crank shaft passageways. The normal check is to reach inside the oil pan and try to rotate the outer housing roughly 10 degrees. Sometimes they get gummed up with sludge after years of service depending on the oil quality and change intervals.
In my opinion, this engine in question definitely has an issue with the Damper, Flywheel or Crank itself as the vibration reportably began directly after the crankshaft was replaced due to a connecting rod failure. All this needs to be looked at very closely and it will be, however on this particular job in question the client wants a vibration study done before moving forward. More than anything this is for them to have some printed data to share with their superiors other than a statement that there is excessive vibration (how much? is the first thing that will be asked)
So rather than breaking the bank and purchasing expensive equipment that can do all sorts of neat stuff (if you are properly trained to use it), my simple approach is to use the Fluke to measure the absolute vibration level at various points on the engine and generator package in question as well as the other two alike units operating in the engine room with no excessive vibration. This data will then be used to create a report that the management should be able to see in simple numbers that there is in fact an issue that needs to be corrected. So it wont be a lot of data, but its all in the presentation at times
Register to Reply 19 comments
4wsilver (1); BruceFlorida (2); Drew K (2); Edbear (1); fixitorelse (1); Haroldus (1); leveles (1); pritam (1); SHOCKHISCAN (1); tecmate (1); Tim in Mexico (7)
