Previous in Forum: Antiskid Boat Deck and Side Tops   Next in Forum: Wire Drawing of High Tensile Strength and Tough Material
Type of Flanges
05/27/2013 2:55 AM
Q:1-When Weld neck flanges are prefereed?? Some reason I think are as below
When 100% radiography is required.
Lethal service.
Apart from above in case of Sour Service and specially Hidrogen service is it mandatory to go for weld neck flanges?? Also please specify other requirements if any??
Q:2-When reverse flanges or Nut stop type flanges are used?? Any specific service in which these flanges should be used?? I have not designed so far these type of flanges.
Pathfinder Tags: manufacturing
Re: Type of flanges
05/27/2013 5:26 AM
What code are you referring to?
If you use weld neck flange it needs a test if done correctly, hence it requires radiography or any other test. So it is the other way around!
Check out:
http://www.google.com/search?sourceid=navclient&aq=&oq=weld+neck+flanges+design+application&ie=UTF-8&rlz=&q=weld+neck+flanges+design+application
Re: Type of flanges
05/27/2013 1:00 PM
It is hard to get a good radiograph on the weld for a slip-on or socket-weld flange (too much material in the way). So the OP is right on that point. It does depend on which Code is to be followed.
Re: Type of flanges
05/27/2013 11:05 PM
Ok live and learn.
To elaborate more on it. My thinking is: You have to radiograph or test the weld one way or the other. Which requirement comes first I cannot tell. Found this. Seems a nice wrap up of things.
Found this too and this.
Good Answers: 34
Re: Type of flanges
05/27/2013 7:18 AM
Sure. Lethal service? ASME B-31.3 ????
Good Answers: 104
Re: Type of Flanges
05/27/2013 2:09 PM
Q1: Preferred over what? slip-on or socket weld? I think high-temperature is another, maybe the most important, driver of weld-neck over slip-on. Another issue is crevice corrosion with socket weld. In my petrochem experience, under 2" was usually socket weld and over 2" was usually butt-weld (weld neck). 2" was sometime socket weld, sometimes butt-weld, and I have seen butt-weld down to 1/2". Only cooling water and similar service used slip-on.
Q2: What are reverse flanges and Nut stop flanges?
Good Answers: 34
Re: Type of Flanges
05/27/2013 2:10 PM
H2 does not necessarily have to be considered lethal fluid.
See ASME B 31.3 (Refers you to Chapter VII, Point 341.4 for NDE)
I recommend (Sorry) ensured flanged union with additional helium test.
WP
Good Answers: 34
Re: Type of Flanges
05/28/2013 9:52 AM
1.- Socket weld flanges (Small bore) will be checked with RT examination. (Fillet weld and gap verification)
2. RT for slip on is complicate but:
1.- Slip-on flanges will be provided with a vent and pneumatic test 1/8 inch NPTdrilled hole on the neck prior to welding.2.- A pneumatic test shall be done after welding of slip-on flanges, at a pressure of0,7 - 1,03 barg (10 - 15 psig), for, at least, 5 minutes.No leaks are permitted. Hole shall be filled with appropriate grease to prevent from
entering water
WP
Register to Reply 7 comments
bigg (1); IdeaSmith (2); Tornado (1); Whitephone (3)
