I have a small building built almost 2 years to date. The construction is 2 floors with an area of 160 square meters per floor. I have reviewed the plans (for a 3 floor building) and found out that the base foundations specs were all met except the posts which is supposedly be using 8 pcs of 16mm diameter corrogated bars. They only use 4 pcs of 16mm. If I extend my building upward adding one more floor (3rd floor), what is the best way to correct or modify the structure to have a safety building construction.
Your comments and suggestions will be highly appreciated.
