Previous in Forum: Phase Fault Problem in ACS800 Drive   Next in Forum: PHASE FAULT Problem in ABB ACS850 drive
Switchyard
06/08/2013 1:18 PM
i want to know the methodology involved for calculating the area occupied by the switchyard?
Re: switchyard
06/08/2013 1:42 PM
Well it depends on how many lines you will be switching.
A table can help.
It will also be necessary to know the gauge of the track.
Remember, if your not precise in your question on a public forum somebody will always misunderstand you.
Re: switchyard
06/08/2013 1:50 PM
Thanks for your reply sir,
I appreciate your suggestion.
well the details would be-
765kv switchyard, total generation 2*660 Mw for a thermal power plant
Re: switchyard
06/08/2013 3:07 PM
Why did you guess that an Indian power plant document would be relevant?
Re: switchyard
06/08/2013 3:30 PM
Superior powers of deduction?
Re: switchyard
06/08/2013 3:55 PM
Draw it up on a computer with all the gear represented to scale and extrapolate from there.
Re: Switchyard
06/10/2013 3:30 AM
A square grid laid over an aerial photograph works well. Simply count the squares that are more then 50% inside the switchyard area and multiply by the area of each square at the scale of the aerial photograph.
Register to Reply 6 comments
lyn (1); PWSlack (1); redfred (2); rish00760 (1); tcmtech (1)
