Previous in Forum: Computer Vision   Next in Forum: Printing Blank Pages!
Automation To Run Any .exe File
06/10/2013 11:03 AM
Can you please suggest me as how to build an automation tool which runs .exe file??
For example i want to install VLC player with the help of automation tool where all things has to be in the control of automation tool.i.e automation tool has to select the path as where to install the software(path to be specified manually but automation tool has to select the path which is specified by us)
Can u suggest me that kind of automation tool
Re: Automation To Run Any .exe File
06/10/2013 3:54 PM
You can download free or paid packages that do this
For example
Good Answers: 22
06/10/2013 10:56 PM
... or you could write a script to do it using either a freeby like http://www.autohotkey.com/
or buying a scripting tool like MJTnet.com (which has more features than the freeby)
06/11/2013 8:06 PM
First off you need an installer. http://en.wikipedia.org/wiki/List_of_installation_software
Then you will need to be a great deal more specific as what you plan to do. I think VLC will accept a file spec parameter which is essential for your project to work. If you intend to build an application your concept needs to be crystal clear.
Register to Reply 3 comments
aDIYguy (1); jack of all trades (1); RobertOz (1)
