Previous in Forum: How Does the Light Barrier Differ from the Doppler Effect?   Next in Forum: Chipper Vac - Need Some Ideas
13 comments
Visual Effects from an Anti Gravity Device
06/10/2013 1:59 PM
If it were possible to obtain a device that could generate a gravity field, it would be reasonable that you could aim it in any direction. If you could set the power level you like, then you could propell yourself around with significant ease.
But since light is affected by gravity, would not a visual on something with its own gravity generator tend to blur as if on a horizon as it moved?
Re: Visual Effects from an Anti Gravity Device
06/10/2013 2:42 PM
Is this Wesley Crusher????
06/10/2013 2:43 PM
Too bad you are posting anonymously otherwise I would have gladly gotten into this thread!
Oh well better luck next time.
06/10/2013 3:22 PM
Too theoretical for my tastes, we still know so little about gravity.
My guess would be no, regardless of all the movies which show a distortion field effect.
If we look at magnets (permanent and electromagnets) these don't bend light noticeably at field strength levels we can generate. Just an example as without knowing how the anti-gravity field is being generated it is difficult for me to speculate.
Interested to see if others here have a better take on the concept.
Good Answers: 69
06/10/2013 4:34 PM
It depends; absolute gravity, or relative gravity ? .
Good Answers: 114
06/10/2013 6:33 PM
It is the gravity of the situation.
06/10/2013 10:30 PM
It depends on if you have the older model AK15L or the newer model B1000 with distortion correction....
Good Answers: 22
06/11/2013 2:28 AM
Let's take a device that generates a gravity field... hmmm ... oh yes - some mass!
Get yourself a jar full of coins. Hold it up - does it appreciably distort the light? I think not. Get some more mass... say, Mt Fuji. Stand back. Does it distort light? Nope. Let's add some more mass... hmm - the sun! Yes - light distorted (testable if you have some equipment that measures in micro-arc-seconds).
So I'd be guessing your theoretical gravity field generator would not cause visible lensing. I would also predict it would not be directional (any more than the gravity of any mass is directional). Gravity waves appear to propagate in all directions (like light). To make them directional you would need to discover a substance that would reflect gravity waves (like many substances reflect light waves) - nothing known does this for gravity, but where there is science there is hope.
06/11/2013 3:20 AM
Gravity is a misnomer. Actually, the Earth sucks.
Good Answers: 32
06/11/2013 3:27 AM
That explains the haze under Luke's speeder.
johny451
06/11/2013 6:52 AM
Rumour has it that, following the success of their AnyWhen© time machine, KrisDel™ is working on a prototype anti-gravity device right now. The equipment is in place to manufacture it - look here.
Good Answers: 114
06/11/2013 8:04 PM
When I read the title of this thread, I wanted, oh yes I wanted to... but I held off...till now.
The OP demonstrates a distinct lack of gravity.
Good Answers: 73
06/13/2013 8:15 AM
Consider some sort of vehicle that has a small anti-gravity generator, like a motorcycle with the device replacing the motor. If it were canceling gravity for its mass, with or without a rider, then the light under the cycle would shimmer under the generator like a heat wave, due to the gravitational distortion.
Standing too close to one of these when it accelerated away might knock you over due to the antigravity force wave (like a gravity wave, only repulsing instead of attracting). If Newtons laws of motion still hold that for every action there must be a reaction, then an antigravity cycle would exert more force to accelerate away from some point. Consequently, there would be a tidal wash of force expressed in the opposite direction of acceleration. Any thing in its wash would feel a windless wind.
06/16/2013 1:30 PM
Since gravity distorts spacetime, it should be safe to assume there would be a time distortion wave associated with the 'tidal wash' you speak of, ie; you could not only be knocked down, you could be knocked back in time, however briefly....
jack of all trades (1); Johny451 (1); JPool (1); NotUrOrdinaryJoe (1); passingtongreen (2); PWSlack (2); RobertOz (1); SolarEagle (2); tcmtech (1); Yahlasit (1)
