Previous in Forum: Drop Bottom Furnace   Next in Forum: Backup Overcurrent Protection
How To Solve Problem on ETAP Wind Turbine Generator Simulation
06/15/2013 12:23 AM
in this system I use "load flow analysis", but after the run etap say
"Error 2000: Number of energized buses is less than two" and
"Error 2002: The system has no branches energized"
I do not know where the location of the disorder, can you help me to solve this problem?... I also do not quite understand, if the system that I've made have been right or still wrong?
Re: how to solve problem on etap wind turbine generator simulation
06/15/2013 2:32 AM
06/15/2013 9:11 AM
thank you sir, i will read it carefully
06/15/2013 5:36 AM
u have to have cable or transmission line between the source(i.e generator) and load, and also put generator on swing mode.
06/15/2013 10:59 AM
thank you very much sir, because your advice my simulation can be run, if I get a problem again, I would probably ask to you sir,, :D
Register to Reply 4 comments
lyn (1); Shanders (2); vyral2311 (1)
