Previous in Forum: How To Solve Problem on ETAP Wind Turbine Generator Simulation   Next in Forum: OMRON 's Inverter V1000
Backup Overcurrent Protection
06/15/2013 1:23 AM
can anybody help me working out settings for voltage restrained overcurrent protection?
I want guidelines on how to calculate both voltage levels? current setting and TMS are already worked out.
Good Answers: 170
Re: Backup overcurrent protection
06/15/2013 3:18 AM
What about the manufacturer's instruction manual?
06/15/2013 5:24 AM
relay is micom p343, it suggest that set the voltage threshold, V Dep OC V<2 Set to a value above the voltage measured at the relay and upper voltage threshold setting, V Dep OC V<1 Set, should be set below the minimum corrected phase-phase voltage level for a close-up HV earth fault.
But through this information I am not able to make out. Plz help
06/15/2013 1:44 PM
If voltage is being measured in range as 395 V to 412 V ; this Upper voltage threshold is to be set below 395 V (1) .
More than 412 V , this voltage threshold(2) is to be set .
06/17/2013 5:02 AM
PT secondary is 110 v, then what should be the settings?
06/17/2013 12:20 PM
Considering the phase to phase voltage as 110 ;
104 V as Below 110 can be opted - provided we are not getting this reading in loaded / fully loaded / start up - condition ( normal ) .
120 V as above 110 V may be chosen based on no load / min load condition - being measured in different shift timings .
If volage and upper voltage threshold required for us is being interchanged , overcurrent protection will be activated . In that case , interchange these values as well - please .
Phase to phase voltage if is different , work out the value in a similar way . Regards .
electricalexpert65 (1); sivaa (2); vyral2311 (2)
