Omron does not make drives, they just brand label them from Yaskawa, so that is a Yaskawa V1000 inverter drive. The parameter list is similar, but not exactly the same. However if what you are really asking is if you are used to the G7 programming, and you change to a V1000, will it program in the same method as far as the look and feel? Yes. But can you ASSume that the parameter list is exactly the same without checking? No.
