Previous in Forum: Air Handling Unit Temperature   Next in Forum: Making an Idea Pay?
Bearing Moving on Steam Heated Shaft
06/16/2013 6:31 AM
We have a problem with a bearing moving on the steam (160 degrees) heated shaft of a large machine here. The bearing tapered sleeve seems to move along the shaft away from the machine.
The shaft was machined and sleeved in situ about 9 months ago, after there were problems with some shaft damage. Not sure what they did, but it pushes the bearing through the block where it ends up resting against the end of the block.
Any thoughts on how we might stop this happening?
Re: Bearing Moving on Steam Heated Shaft
06/16/2013 6:36 AM
Clamp a two-piece shaft collar against the bearing.
06/16/2013 12:46 PM
This statement, "after there were problems with some shaft damage. Not sure what they did" assures that we will never know what happened to the shaft, or bearing.
Do as Tornado said, or weld it in place.
06/16/2013 10:56 PM
contact bearing manufacturers.
pnaban
06/16/2013 11:04 PM
There are two types of tapper sleeves are in use, Adaptive sleeves and Withdrawal sleeves. Which type is yours?
Adapter sleeves:
Withdrawal sleeves:
Can you attach a sketch detailing your machine/bearing area?
06/17/2013 12:12 AM
Chk for the tolerance of the orginal shaft and the tolerance to which the shaft was machined to
06/19/2013 5:34 AM
Set screws loosening from thermal expansion/contraction cycles (steam can work wonders)?
06/26/2013 9:09 AM
Similar to cooling gland packing try for bearings.
pnaban
Register to Reply 7 comments
lyn (1); Mr Fixit (1); pnaban (2); rastovsh (1); Tornado (1); yesyen (1)
